Hood support
Old Feb 2, 2017 | 04:13 PM
sunsetseeker's Avatar
Default Hood support
Hi! New member here. I just purchased a 2005 Roadster and am having some problems. First seems to be a common problem with the battery drain. The battery and the charging system is fine but the battery goes dead in about two days if not driven. I did the test unhooking the battery and connecting a tester between the negative terminal and the cable. I have about a low 60's draw somewhere. Pulled all the fuses in the compartment near the battery, but nothing changed. The real reason I am posting is the hood support (lift-o-mat). When I bought the car it was in the trunk. I am unsure how it attaches. The lower end is simple. Just the normal ball. I don't see how the top fastens. The hood has a pin sticking out and I can see how a "C" type clip would keep it in place. The end of the support has a button that says "press", but I must be missing a piece to connect the two. Can one of you gurus tell or show me what I need to get it hooked up? It will make the trouble shooting on the drain much easier. Thanks in advance for any and all help! I really love this car!!
Gary
Old Feb 2, 2017 | 04:45 PM
Mrmiata's Avatar
Default Re: Hood support
You have the charged cylinder?
Old Feb 2, 2017 | 04:52 PM
Mrmiata's Avatar
New Hood Lift Support Shock Strut Damper Fits Mercedes R170 SLK230 1708800229 | eBay
Old Feb 2, 2017 | 04:57 PM
And as to the battery drain, it's the fuses in the box on the drivers side that you need to pull one at a time, not the few in the black box by the battery.
Old Feb 2, 2017 | 05:13 PM
Here is all I have. It seems I am missing the upper end piece???
Old Feb 2, 2017 | 05:35 PM
Yes, you certainly are.
Old Feb 2, 2017 | 10:07 PM
RKC00's Avatar
Worked For Me...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Feb 2, 2017 | 11:29 PM
Mrmiata's Avatar
Originally Posted by RKC00
Full vertical with the "right" assembly... cars towards the end of these..
Old Feb 3, 2017 | 09:52 AM
Whenever I raise the hood and it will be left raised for a while I always raise it to the vertical position. I think that takes the strain of the internals of the cylinder and helps it last longer.
I maybe right or wrong but it cannot do any harm.
Old Feb 3, 2017 | 12:19 PM
I might be getting closer to the battery drain problem. The radio fuse eliminates the excess amps. I have temporarily removed the fuse to see if that helps. I did put a CD in the slot and it got stuck. I'm guessing it continually tries to either load or eject it causing the drain. Now I need to figure out how to get the disc out.....
I really appreciate all the help!!
Gary
Old Feb 3, 2017 | 12:25 PM
Gary
You are welcome.
Want some more advice ?
Junk the OEM radio and get something more modern with USB/MP3 and BlueTooth.
( Hint : look at the Marine radios, many are silver and almost match )
for $40 from amazon, this one seems to fit the bill :
https://www.amazon.com/Lanzar-AQMP70...=marine+radios
or if you don't need the cd player, many chose this one ( the center spine even blends in ) :
https://www.amazon.com/Clarion-Corpo...=marine+radios
Old Feb 6, 2017 | 02:21 PM
Managed to remove the disc and the battery drain has disappeared! Now I am waiting for some parts to arrive Wednesday to be able to fasten the hood support to the hood. Once again.... Many thanks!!
Old Feb 7, 2017 | 01:14 PM
hokkabaz's Avatar
just in time! thank you for the share.
People in Walmart Car Center (or whatever they call themselves) broke the original one while changing the battery!!!! I pushed them to check the cameras etc and they accepted to pay for the part and labor +refunded the money for the battery (normally about $100).
I went to Chrysler dealer and got a quote which was almost $400! for the strut and labor(lol)
got the money from Walmart and now I am about to order one of these.
I am pretty happy at the moment lol.
