At my wits end!!
Old Sep 9, 2018 | 03:52 AM
8ighth Wonder's Avatar
Default At my wits end!!
My crossfire has again started acting weird!!
The symptoms are random and as follows:
1) All dash lights on while driving, at times the shift position indicator reads "P" while in D. When this happens the car is struggling to reach 30mph
2)Coolant, oil, Check engine and BAS flicker while driving.
3) Sometimes it starts after disconnecting the battery, sometimes it does a partial crank then nothing.
No codes present at the time.
RCM has been modded bu DJ, Batt and alternator are new and have been checked. Voltages are stable.
Old Sep 9, 2018 | 07:15 AM
Default Re: At my wits emd!!
Sounds like a flaky ground connection, battery to frame, or engine to frame.
Old Sep 9, 2018 | 07:17 AM
battery to frame is good not really a voltage drop there. Where is the engine to frame connection?
Old Sep 9, 2018 | 07:26 AM
Upon researching it seems ill have to add one. I had an issue like this before on a RADAR. I'll give it a shot.
Old Sep 9, 2018 | 07:42 AM
Let me add, no problems starting it now that it's cooked off
Old Sep 9, 2018 | 07:50 AM
Driver side, bare copper mesh wire.
Old Sep 9, 2018 | 02:20 PM
Did a chat with DJ very informative, I learned a lot about the RCM. Led me back tui the CPS. When I push the wire towards the front of the vehicle it runs fine. When I push it thi the back it dies or the lights all come on, fan speeds up, etc. Going to replace the sensor first as it's not a Bosch.
Old Sep 9, 2018 | 03:49 PM
Default Re: At my wits end!!
Please let everyone know the outcome.
Old Sep 9, 2018 | 10:00 PM
Changed the CPS; A CPS code, trans range code and serial data link code popped up. I drove it for an hour all codes cleared. It's looking good so far.
syfi
70
Nov 4, 2019 01:52 AM
Franc Rauscher
Sep 2, 2017 02:05 PM
crosscats
Jun 10, 2017 02:22 PM
Padgett
Mar 8, 2017 05:14 PM
r.robertson
Apr 12, 2004 04:28 AM
