Supercharged??
Old Feb 17, 2019 | 12:25 AM
Jaime's Avatar
Default Supercharged??
Is there a way to supercharge a Chrysler Crossfire 2006 limited ??
Old Feb 17, 2019 | 07:58 AM
Southernscrew's Avatar
Default Re: Supercharged??
The best way for that is buy an SRT, You would have to change the bottom end and a whole lot more !!
Old Feb 17, 2019 | 08:43 AM
UrbanE's Avatar
You can buy one already installed in a car for 10-20k
or you can do what I did. Convert one and pay a lot more.
You need everything from a donor so you may as well just buy one
Next time I’ll just buy one and save myself a bundle. Cheapest option
BUY ONE
Trust me
Old Feb 17, 2019 | 12:35 PM
DualSportDad's Avatar
I have to ask why... Or what made it so expensive? I see a complete engine and trans in my area right now for $1500, pulled from a totaled car. It has me thinking......
Old Feb 17, 2019 | 01:32 PM
UrbanE's Avatar
Engine
new hoses
transmission
drive shaft
Pumpkin
half shafts
when you pull these, best to redo the bearings
POWER steering hoses
fuse block is different
tranmission lines because of the intercooler
different location for secondary air pump with new wiring
THESE ALL HAVE TO COME FROM THE SAME CAR
ECU
TCU
BCM
skreem
key with fob
door lock cylinder
$650-$1000 on eBay
will need to get the ECU flashed to work with the deployed wing or find a fixed wing The ECU from the donar will not register the deployed wing
Old Feb 17, 2019 | 01:47 PM
Originally Posted by UrbanE
Engine
new hoses
transmission
drive shaft
Pumpkin
half shafts
ECU
TCU
BCM
skreem
key with fob
door lock cylinder
$650-$1000 on eBay
Thanks, from the sounds of it the guy might have all of this stuff still. Maybe even the whole car.
Old Feb 17, 2019 | 07:08 PM
If it were just the nuts and bolts, it would not be that big of a deal - anyone can turn wrenches and spend the time to make it happen.
But once you get involved with the electronics, THAT is where the real work and money are involved. I also question transplanting ECM, SKREEM, etc. - because if you do that, the electronic VIN changes. Your car has one VIN on the door and under the windshield, but the ECM will have another. When you go in for an emissions inspection, the car wont pass because the VIN in the electronics does not match the title or registration.
The only RIGHT way to do it is to spend the dollars to get Rudy or Josh to do it right.
Old May 2, 2019 | 11:58 PM
Demonsfire's Avatar
Wh
Next time I’ll ju
BUY ONE
Trust me what is everything what do you need to switch it over just so it' runs nothing else?
Old May 2, 2019 | 11:59 PM
Demonsfire's Avatar
What do you need to put a srt6 in a 04 just so it runs nothing else no brake s no suspension ext just to make it drive ?
Old May 3, 2019 | 02:40 PM
SRT engine and no brakes takes money to do and stupidity to drive.
Old May 3, 2019 | 03:43 PM
the easiest way to get the power + a little more of a srt6,,,is to install a aspirated mercedes V8 the ecu is easier to do than limited to srt6.
there have been a few done,,,
+fireamx
Feb 1, 2008 04:18 PM
240M3SRT
Other Cars Etc
Jan 27, 2008 09:31 AM
smokey847
Jun 27, 2006 11:31 AM
cross1
Jul 25, 2005 02:43 AM
macjake
Dec 1, 2003 01:05 PM
