P0410 Error Code after Replacement
Old Mar 14, 2019 | 09:13 AM
HazMatt's Avatar
Default P0410 Error Code after Replacement
Just purchased my 2005 Crossfire Limited Roadster. The previous owner informed me that in March he had the Secondary Air Injection Pump replaced. Now I have a check engine light on and the error code is P0410. I would bring it back to the shop but it's over two hours away. I was hoping to get some input here first thinking it was something simple like a connector or relay. I really do not want to take it to a shop. Any input would be greatly appreciated. Thanks in advance.
BTW- This warning was Yellow, not red, the first time i checked.
Old Mar 14, 2019 | 10:09 AM
Default Re: P0410 Error Code after Replacement
Check for burnt contacts on the air pump relay in the RCM ( located in the box next to the battery, it's the module closest to the engine.
Old Mar 14, 2019 | 10:17 AM
Jim Holian's Avatar
ala-xfire - Very nice pictures and explanation. Thank you.
Jim
Old Mar 14, 2019 | 09:58 PM
HazMatt's Avatar
Thanks so much. I will give it a go and do an update. Can you replace an individual relay or do you have to replace the entire module?
Old Mar 15, 2019 | 12:09 AM
You can, but it is much better to just send it to DJ and have him do it.
He charges around $50 for a 3 relay replacement ( engine, fuel pump & air pump ).
Send him an email at tighed1@hotmail.com for address and instructions.
Old Mar 15, 2019 | 07:37 AM
zip439's Avatar
Check that 50 amp fuse.
Old Mar 15, 2019 | 09:09 AM
We are becoming like stealerships, replace this, send it to. ——,etc.
Lets get back to basics. I cannot see these questions addressed.
Are the points burnt? If so file them clean and see if that works, then replace the burnt relay.
Are the solenoids working?
Is that blue valve working?
Are the hoses to the two valves in good shape and connected?
Is the ground wire clean?
Does the pump run and shut of within a half a minute?
Is the pump running continuously?
Old Mar 15, 2019 | 10:11 AM
waldig's Avatar
From a while ago..........enjoy. Woody
https://www.crossfireforum.org/forum...10-yippie.html
Old Mar 15, 2019 | 11:04 AM
HazMatt's Avatar
Thank you.
hbv2020
Jan 5, 2013 07:44 PM
nate_man
16
Mar 11, 2012 10:10 PM
palexfire1
Nov 18, 2011 10:23 AM
gsimonsen
Apr 19, 2011 04:31 AM
04chryslr
Jul 31, 2008 11:36 AM
