Convertible Top Module
Old Sep 29, 2020 | 08:13 AM
Viper-666's Avatar
Default Convertible Top Module
Hello,
I build a Top Module for the Roadster years ago with through hole components.It looks like this:
Top Module through hole
I had many questions if I wanted to do a new series of them.
Because the whole soldering of the components causes a lot of work and is not so professional I had the new edition made in SMD construction. This looks like this:
SMD-Version
And with housing like this:
With housing
What can the module do?
Open and close the top with a short press of the button.
Stop the opening/closing process by pressing the button again.
Automatic raising up of the windows after the top has been opened/closed completely.
Open/close the top up to a speed of 30mph (at your own risk you are responsible for not damaging the top. If you still have a headwind the wind speed will increase accordingly).
Here is a video where you can see the function:
And here a installation video:
Here the installation and operation manual:
https://crossfire-forum-deutschland....l_Englisch.pdf
Old Sep 29, 2020 | 08:56 AM
Default Re: Convertible Top Module
Brilliant!
Nice work.
Old Sep 29, 2020 | 09:20 AM
Viper-666's Avatar
Thank you, to find out how I can get the Top to work at speeds over 4mph was really hard...
Old Sep 29, 2020 | 10:16 AM
Now if someone can only figure out a way to bypass those pesky top sensors that break.
Old Sep 29, 2020 | 10:27 AM
That's easy, just connect the 2 leads together on both sensors.
WARNING !!!!!
If you do this, :
1. Do NOT press the down switch with the header latched.
2. Do NOT press the down switch with the divider in the stowed position and something in the trunk higher than it would be in the top down position.
Old Oct 23, 2020 | 02:09 AM
Viper-666's Avatar
Default Helloween Sale
Hello,
for Helloween there is a limited "special multicolor edition" of my top module.
This special edition is limited to 5 pieces and is reduced by $15, so be quick!
The photo is only an example, there are different color combinations available.
Old Nov 27, 2020 | 01:51 AM
Viper-666's Avatar
Default Black Friday Sale
Black Friday Sale
You can get a Top Module for $114 + $10 shipping costs.
Old Nov 24, 2021 | 01:20 PM
Viper-666's Avatar
A other Black Friday Sale
You can get a Top Module for $109 + $10 shipping costs.
Old May 18, 2026 | 03:50 PM
SALEEN032's Avatar
Im guessing this is a long shot, but I just bought my wife a 2008 Roadster and was wondering if you might still have a Top module for sale?
Thanks in advance,
Scott
Old May 19, 2026 | 10:37 AM
He posted here 13 days ago, so you should hear from him soon - he is still active here.
My caution would be this: Module failures are really rare. Iv'e fixed, well, I really don't know how many tops I have fixed -not ONE was due to a bad module. I am NOT saying they do not fail, I am saying that module failures are really, really rare.
MOST people chasing a top issue (and in fact most electronics issues) make things way too hard. I had to learn this in 1982 on my first job as an electronics tech because I was doing it as well. MOST electronic issues are essentially very simple failures, but not simple to diagnose.
I offer this thread to help people, it helps yo u understand how the system works, so that you understand more of what is (or could be) wrong:
https://www.crossfireforum.org/forum...p-sensors.html
Old May 19, 2026 | 11:29 AM
SALEEN032's Avatar
Thank you for the response and explanation, but my top is working fine. I am interested in the One-Touch module he makes that makes operation one touch instead of having to hold the button....
Old May 20, 2026 | 06:44 PM
His distributor here in the states is @rcompart Last I knew, Rudy still had a few in stock.
I"ve tagged Rudy.
Old May 21, 2026 | 08:40 AM
SALEEN032's Avatar
I"ve tagged Rudy.
Thank you. I sent Rudy a PM.
jonq67
Jan 19, 2020 10:15 PM
Darth
Apr 29, 2019 03:56 PM
kevingb
Aug 8, 2018 06:53 AM
pizzaguy
Jan 28, 2013 12:27 AM
SoftballJunnkie
Jul 19, 2011 06:29 AM
