Cable tonneau flap side wanted...
Old Aug 15, 2021 | 01:59 AM
danao91's Avatar
Default Cable tonneau flap side wanted...
Hello Guys,
I'm looking for 1 cable tonneau flap side 05140962AA, but I don't find, any idea ?
I'm based in France.
Thanks in advance.
Old Aug 18, 2021 | 04:34 PM
P-J's Avatar
P-J
Default Re: Cable tonneau flap side wanted....
I don't believe these are available any longer. I replaced both of mine a number of years ago as both got hung up in the cable sleeve. My suggestion would be to disconnect the cable and take it to a shop that repairs convertible tops and see if they can make one or two for you. Another option would be a salvage yard but you may run into the same problem. If/when you are able to find a replacement be sure to use a cable lube tool and cable lube to lubricate heavily before you re-install. Good luck!
PJ
Old Aug 18, 2021 | 05:26 PM
I've also read bike shops can make them?
Old Sep 3, 2021 | 01:50 PM
JimJer's Avatar
I just had mine pull apart at the end fitting and am trying to repair by drilling out the fitting slightly and refitting the cable with JB Weld steel reinforced epoxy. I had to scrape the nylon coating off to give the JB Weld a better grip on the stainless cable. If it broke elsewhere head to the bike shop but keep the end fittings if possible.
martyn
U.K.
38
Aug 6, 2023 06:46 PM
martyn
U.K.
Feb 19, 2018 01:56 AM
frogwash
Aug 14, 2015 03:44 PM
g3air
20
Sep 19, 2014 02:16 PM
willdv
Sep 3, 2014 10:29 AM
