Trunk light fuse
Old Feb 23, 2022 | 05:25 PM
P-J's Avatar
P-J
Default Trunk light fuse
In changing what I thought was a burnt out trunk bulb ends up possibly being a blown fuse as the bulb is fine. Can someone tell me what fuse is associated with the trunk light, not in the manual? I checked the interior light fuse #31 and it is good.
Old Feb 24, 2022 | 03:11 PM
dcskmail's Avatar
Default Re: Trunk light fuse
I found this on the forums not sure if this applies to a 2006 The dome light and cargo light are common to fuse 9 in the under hood accessory block.
In automatic mode, the ground to cause them to light is supplied by the BCM ( Body Control Module ) on pin 18 of connector 4.
The BCM is reading all the door and lift gate / trunk switches ( via the CLP - Central Locking Pump ) in order to determine if the lights should be on or off, so I would suspect one of those 3 would be the culprit. Hope this helps
Old Feb 24, 2022 | 03:19 PM
Ronman's Avatar
Unfortunately every time they built a car the fuses were moved around. Hopefully the OP still has the card inside the under hood accessory block and he can try what you suggested.
Old Feb 24, 2022 | 03:25 PM
P-J's Avatar
P-J
Thanks guys, much appreciated...raining and 38 degrees here today, I will check it tomorrow and let you know if this fuse is the culprit.
Old Feb 24, 2022 | 03:38 PM
Have you checked both trunk lamp terminals to ground, to see IF there is 12v (nominal) on a voltmeter? With one door open, normally, you should get system voltage on one of them terminals. If not, an open circuit or fuse is suspect. Does your dome light come on when the door opens? If so, then you should have that 12v (nominal) at one of the two terminals (to a good ground point). I would not use the other terminal for the ground because it could be 'open'. Good luck!
Old Feb 25, 2022 | 02:13 PM
P-J's Avatar
P-J
Ok, the old man needs to get his eyes checked. Per dcskmail, I checked fuse #9 and it was not only blown but it is in plain view on the fuse card. I did check both bulb terminals and nothing, no interior light either. I replaced the 10A fuse and all is good. Here is a photo of the fuse chart for anyone who may need it.
Old Feb 25, 2022 | 11:11 PM
Jack G's Avatar
PJ
If your lamp is an LED it might be polarity sensitive. Try inserting it 180 degrees opposite from its present location.
Old Feb 26, 2022 | 10:22 AM
P-J's Avatar
P-J
Jack G
Thanks, it is an LED and all is good now per above.
Old Feb 26, 2022 | 10:57 AM
Jack G's Avatar
Did you check the presence of voltage across the lamp contacts? This will indicate if your fuse is blown even if you do not know its location. Also, check to see if lamp holder wire connections are good. You might also want to check the switch that turns on the light.
Have you ever considered installing a second lamp? I did and it improves visibility considerably.
Yvonne
Jun 12, 2019 04:19 PM
QUEBECOIS
May 11, 2018 04:18 PM
lildaddym
Apr 2, 2014 07:03 PM
davecr1
Mar 7, 2014 05:35 PM
Bubba89
Nov 25, 2008 10:58 AM
