Bizarre Electrical Problem
Old Jun 18, 2022 | 01:24 PM
griffinregan's Avatar
Default Bizarre Electrical Problem
I’m going to try my best to explain this. Every so often, I’ll go to start my car, everything is fine until I turn the key to start the engine, then all electrical is cut to the car. The only fix to this that I have been able to find was touching the positive battery terminal. This would shock my finger just a little, and all electrical would return, and the car would start as normal. This problem happens randomly, no pattern I’ve been able to detect
With my very little electrical knowledge, is this a ground issue? I have never heard of a car doing this
Thanks for any insight
Old Jun 18, 2022 | 02:37 PM
tighed1's Avatar
Default Re: Bizarre Electrical Problem
Remove battery cables. Clean the battery terminals and cable clamps. Reinstall battery cables.
Old Jun 19, 2022 | 06:18 AM
Also, check the points where the battery ground cable attaches to the chassis (for any corrosion or damage) and where the engine to chassis grounds are under the car from the engine/transmission bell housing to the frame. Hope this fixes this strange issue!
Fuya
15
May 15, 2017 11:09 AM
skeet370
29
Sep 18, 2015 05:53 AM
Tomqn1
Aug 11, 2013 08:08 AM
blond xo
Oct 26, 2012 12:49 PM
dcspride
Jan 29, 2010 08:42 PM
