UK Roadster Thread - drilling into the trunk
Old Mar 17, 2023 | 01:19 PM
Default re: UK Roadster Thread - drilling into the trunk
I believe the emblem is glued on and is removed by running fishing line or ? to break it loose. I don't know where the hole would be in relation to the lock.
Old Mar 17, 2023 | 01:29 PM
Padgett's Avatar
Interesting, coupe does not have a handle. Is the lock electronic also ?
Old Mar 17, 2023 | 01:39 PM
Coupes have:
1)Pneumatically operated lock triggered by the button on the dash/console and the SKREEM module. (When locked, latch handle is "floppy".)
Roadsters have:
1) Pneumatically operated lock triggered by the button on the dash/console and the SKREEM module. (When locked, latch handle is "floppy".)
2) Electric lock operated by the Top Controller that locks the lid for the 28 seconds or so when the top is moving up or down. (When locked, latch handle is "Stiff" and won't move.)
Old Mar 18, 2023 | 07:30 AM
Haydyn's Avatar
Thank you. Hopefully someone will have their trunk liner off and send me a photo.
Old Mar 18, 2023 | 07:35 AM
Haydyn's Avatar
Thank you. I’ll send the camera in today and see if I can find it.
Do you have any thoughts on removing the Chrysler emblem and trying to get to the Cam from there?
Old Mar 18, 2023 | 10:54 AM
I have a guy on Facebook who is near you and says he's like to help. I"ve asked if he's on the forum and am waiting a reply, I THINK he's here.
If not, here is his FB:
...yad//www.facebook.com/profile.php?id=100006029051096...
remove THE "...YAD//" FROM THE LEFT AND THE ... ON THE RIGHT.
RObert Richardson
Old Mar 18, 2023 | 11:00 AM
Bill F's Avatar
https://www.crossfireforum.org/forum...echanisms.html
Old Mar 18, 2023 | 11:32 AM
Lots of people trying to help but no one reads the entire thread. looking at trunk lids on Ebay, it appears making a hole where the emblem is may give access.
Old Mar 18, 2023 | 12:59 PM
Fine, but EVERY ONE OF US have gained access to a locked trunk without damage to the car. Read "Trunk Lid Jammed" in this section (Crossfire Roadster); NO ONE could be as clueless and inept as I was back in 2009 and even I got in without damaging my car. This individual is running his camera in too far, and missing the cam on the left, as you go in thru the right side tag light hole. Bob McCubbin has pointed that out but this poster does not believe Bob or I.
He is convinced HIS car is unlike all the others because he is in the UK. But Robert on Facebook who lives in the UK and has a Roadster disagrees, and is going to try to help him locally.
Old Mar 19, 2023 | 04:27 AM
bmccubbin's Avatar
Have tried that, no response from the button because the roof has not fully closed so she’s in self protection mode. I need to manually finish the roof cycle. Easy if you can get in the trunk.
Even if the top is not working, the backdoor trunk lock release should still work if you do it correctly. I have done this many times to get into the trunk because someone's top wasn't working and the trunk won't unlock with the center console lock/unlock button.
Old Mar 19, 2023 | 05:41 AM
Haydyn's Avatar
RObert Richardson
Thank you so much. I shall get in contact today. 🕺🏼
Really appreciate your help.
Old Mar 19, 2023 | 05:50 AM
bmccubbin's Avatar
Here's some pictures that might help with unlocking the trunk lid from either of the license plate light openings. These are on a LHD Crossfire and I don't know if RHD is reversed for the pneumatic lock and the Secondary Electric Lock Actuator Module.
Old Mar 19, 2023 | 06:05 AM
Haydyn's Avatar
Thank you for these… I’ll send the camera in again to find what I’ve missed.
cheers
Haydyn
Old Mar 19, 2023 | 02:45 PM
Haydyn's Avatar
Default Re: Please HELP! Need to drill into the trunk better video update:
Old Mar 19, 2023 | 03:42 PM
cheers
Haydyn
The first two pictures are the coupe latch.
Old Mar 19, 2023 | 04:12 PM
bmccubbin's Avatar
It definitely looks like your Roadster lock is blocked by those plates. You are probably right that going under the Chrysler emblem and drilling a small enough hole to get a very small screwdriver down to the Secondary Electric Lock Actuator Arm and then the pneumatic lock lever, to release the boot (trunk) lid.
Here some pictures that should help with seeing what you need to do, if you decide to drill the hole through the boot lid.
Old Mar 19, 2023 | 10:08 PM
I can't believe this. WHy would a car be so different from all of ours? Is this a UK thing?
WOW do you UK owners want to disable that electric lock as soon as you can!
Old Mar 20, 2023 | 05:12 AM
  #38 (permalink)
bmccubbin's Avatar
They also need to try to remove the security plate on the right side because if the Central Vacuum Locking Pump Module fails then they could still possibly need access to the pneumatic lock lever from the right side license plate light opening.
Old Mar 20, 2023 | 06:09 AM
  #39 (permalink)
Haydyn's Avatar
Apologies accepted
Old Mar 20, 2023 | 10:41 AM
  #40 (permalink)
I think the thing that went wrong here was that the emergency release did not work for you, I see you DID find it and pull on it.
This brings up something from 2009, I managed to open mine with the emergency cable, but the cam did break when I did so. The cam is plastic (stupid) and I wonder if yours is broken as well.
In any event, ya GOTTA disable that electric lock (which is easy, once you get the lid open and can take the trim panel out and access it.
I just can't believe they went this far, but on the OTHER hand, I do know that cars were been stolen at alarming rates in parts of the EU back then.
And I did not apologize YET, I am still in denial.
