Top Open Switch
Old May 19, 2023 | 06:17 PM
CyberCG's Avatar
Default Top Open Switch
Working to restore powered convertible top operations, I have learned a couple of things today.
The first is the microswitch is a Normally Closed switch design. It closes as you push up on the front of the top after releasing it from the windshield header.
The second thing offends my Spidey Senses(engineering for ease of repair). The Top Open Switch body is molded to the plastic bracket that holds the switch and it's activation sliding cam.
AAUGH!!!!
Old Jun 7, 2024 | 04:24 PM
vhrules's Avatar
Default Re: Top Open Switch
Hello, I broke this top open switch, do you know how I can order a replacement or how to rig it? Thanks, Jeff
Old Jun 8, 2024 | 02:10 AM
Originally Posted by vhrules
Hello, I broke this swtich/sensor, do you know how I can get a replacement/ Thanks, Jeff
Here is the part number. I found it on an old post. You can try e bay or an online parts wrecking yard.
Old Jun 8, 2024 | 02:12 AM
This thread by pizzaguy explains everything about Crossfire convertible tops. It is a fantastic write up and will be a great help.
pizzaguy's convertible top thread
Old Jun 8, 2024 | 08:05 AM
vhrules's Avatar
That's it, thank you very much. Wow, $420.00..... Jeff
Old Jun 9, 2024 | 02:01 AM
The older these cars get, the more expensive the parts are.
Shop around as much as you can before paying for anything. You can also put a "wanted" in the Market Place section.
pizzaguy
May 17, 2023 07:16 PM
Dschnbgr
Jan 26, 2022 09:37 AM
notqytryt
Oct 27, 2021 11:45 PM
Belkin7
Aug 22, 2020 08:29 AM
moparperf
Jan 2, 2017 10:06 AM
