Passenger break light won’t shut off
bulb in backwards/////// on your headlight sw there is a right hand only of the car tail lite on(for parking) and a left hand parking only lite.
maybe when u turn off your lights u turn the switch too far . jim
So now all ya gotta do is determine: Is it the Brake light? Then the bulb is in backwards. Is it the tail light? THen you are turning the headlight switch counterclockwise too far.
Easy Peasy! Not only is the owners manual your friend (a .pdf file is in the documents collection), but I believe the socket of the bulb has pin guides that are are offset and match the bulb base (so don't accidently assume the bulb is inserted into the socket correctly). Good luck!
Thank you for the update
sive81364
Feb 22, 2014 10:59 PM
