Gear Shift Knob Replacement
Old Oct 16, 2005 | 09:28 AM
juddz's Avatar
Default Re: Gear Shift **** Replacement
...regarding aftermarket *****, I had a few thoughts. To put this car into reverse, one has to pull the lever upwards, then shift it over and up to get it into reverse. I imagine that a lot of aftermarket ***** (which are often secured in place using allen bolts) would slip off or move, when being yanked upwards to put the car into reverse. In my previous two cars, I always had an aftermarket ****. But then, the shift pattern was always a traditional "H" pattern, and I didn't need to pull up on the lever to get it into reverse.
Old Oct 16, 2005 | 10:08 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Originally Posted by maxxm
If this offer still stands, then Joe Wood has another customer. Please let me know. Thanks.
joe would indeed extend the savings to you. just mention my name to him at time of contact.
cheers! (andrew smith)
Old Oct 17, 2005 | 03:55 AM
bobs's Avatar
Andrew, here's a dumb question. Is that **** for the 6-speed or the autostick?
Old Oct 17, 2005 | 09:28 AM
andrew's Avatar
autostick.
Old Jun 22, 2010 | 03:22 PM
pamelarjohnson's Avatar
Hello all and thanks for being here luv luv luv my crossfire but heres the question my gearshift boot keeps comming off in my husbands hand not mine I believe im alot gentler so is there a pin for this ? It is factory. I have had my 2007 for 2 years now this is my first real problem,,,,,,
Old Jun 22, 2010 | 07:47 PM
Thanks again for being there its the six speed gear shift boot the **** and all just lift off I can always pop it back on but my husband says it must have some kind of pen
Old Jun 22, 2010 | 08:03 PM
I suppose it would be too easy to make a joke out of this, but I will just say that I am glad you do not pull too hard.
Old Jun 23, 2010 | 05:32 PM
thanks I guess I deserve that one next time ill be more carefull decribing things problem still unsolved
Old Jun 23, 2010 | 07:58 PM
I suspect that the nut at the bottom of the **** which is under the boot is not tight enough.
See the sheet from the shop manual I have attached.
Old Mar 28, 2011 | 08:01 PM
Flamenco2005's Avatar
Question Re: Gear Shift **** Replacement
Originally Posted by andrew
real easy to remove & re-install. remove the lower collar by unscrewing it...then pull up hard on the **** to remove it.
my wholesale cost. $115. i can provide you the info to my local dealer and the parts managers name if you have an interest...he is a personal friend. another board member is ordering one from his this week.
I unscrewed the base and pulled up but it doesn't come off. There is a silver looking pin running through it. does that have anything to do with it? I am afraid i'm gonna break something.
Suggestions?
Old Jul 27, 2011 | 11:57 PM
LenardCF23's Avatar
im trying to change my shift **** and i tried to unscrew the bottom of the shift ****, how exactly are u suppose to unscrew it? im really having a hard time, need ur help! thanks
Old Jul 28, 2011 | 06:02 AM
its tight so you should be able to see the dividing grove with the naked eye. grasp it and turn it clockwise. It should come free and you should be able to let it drop down. The rest should be easy. You can check here on somilar threads if you have anymore trouble.
Old Nov 19, 2011 | 04:26 PM
Mrmiata's Avatar
Found something to my liking at Autozone.. Totally reversable to stock. Had to mod shifter **** to get it to sit low enough for my likes.
bbsrt6
Feb 16, 2019 12:39 PM
needfreetime
Aug 1, 2015 07:06 PM
Buchacho
Jul 22, 2015 12:56 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
