Spoiler Help
Old Nov 27, 2024 | 09:20 AM
bunny14th's Avatar
Default Spoiler Help
2007 roaster spoiler not working Man or speed.
New battery with good voltage.
No voltage at motor.
Top works perfect.
Looking for complete wiring diagram from bat to motor.
thanks in advance.
Old Nov 27, 2024 | 11:06 AM
Default Re: Spoiler Help
Did you check your other post for an owners manual?
Old Nov 27, 2024 | 02:01 PM
Top works perfect.
thanks in advance.
The service manual can be downloaded here:
https://www.crossfireforum.org/forum...ollection.html
Look in the "wiring" chapter, but know that the BCM controls the wing, not that switch on the console. The Brake Controller tells the BCM what the car's speed is, and the BCM operates the wing based on that information UNLESS you lock the wing UP with the button on the console.
The CLP/SSM must grant permission for top or wing to move, before either will move. The fact that the top is working tells me that the CLP/SSM is not at fault here.
So it comes down to (in no particular order):
Data from brake controller inhibits operation due to bad data from the BC.
BCM is defective.
Fuse to BCM for wing is blown.
One of the limit switches on the wing mechanism is in an "unknown" position.
Wing motor is bad.
jeromecurrier
May 13, 2024 10:23 AM
boobles37
37
Sep 9, 2012 11:46 AM
TedLast
Sep 10, 2011 12:22 PM
handyman
19
May 12, 2011 03:17 PM
TP150
25
Feb 8, 2005 05:31 PM
