Manual Convertible Top Process - Rear Bow
Old Jun 10, 2025 | 01:45 PM
hamerjn's Avatar
Default Manual Convertible Top Process - Rear Bow
New to the group and working through an issue with convertible top for my 2005. I watched videos from Klaus and Pizzaguy on the manual process. Great videos!
When trying to lower the top after unlocking rear bow latch, the rear bow does not fold up to the vertical position. The rear bow only folds up about half way to vertical. So struggling to unlock and raise the tonneau cover with the rear bow not at vertical
Appreciate any advice or fixes?
Old Jun 10, 2025 | 02:41 PM
Default Re: Manual Convertible Top Process - Rear Bow
Has the pressure bled off?
Old Jun 10, 2025 | 03:29 PM
Are you doing this MANUALLY or are you saying the system is goofing up?
If manually, I'd think the system is still partly pressurized. Pulling the 25 amp fuse to the pump will fix THAT.
Old Jun 10, 2025 | 04:23 PM
hamerjn's Avatar
. manually!!!
I will give it a try! Thanks! Do you know which fuse # and fuse compartment location?
Old Jun 10, 2025 | 07:09 PM
. manually!!!
It varies by year and trim level. See the card in the underhood fuse box, driver's side. That card will mention "Roof Control Unit", it was fuse 5 in 2006 Base/Limiteds, not sure on other years or SRTs.
No704
Mar 29, 2024 07:16 PM
sunsetseeker
Aug 9, 2021 06:02 AM
Moondog
Oct 15, 2020 10:47 AM
hilarushi
Aug 28, 2018 12:33 PM
mike28117
Jul 17, 2015 01:59 PM
