Pulley Options Please!
Old Oct 23, 2007 | 10:36 AM
SRTpowa's Avatar
Default Re: Pulley Options Please!
I'm telling you, there is a malfunction/error in this dyno graph. They are just spikes due to the way they initiated the dyno run. I am pretty sure a stock Srt-6/C32 will not put down over 300 ft/lbs nor 326 with just a pulley. It sill doesn't answer the question of weather or not there is any low end loss, due to the fact that they engaged the dyno at a higher RPM. So if your concerned with any low end loss you might want to wait until they produce a better dynograph, or buy it, go have a dyno session and report back results.
Old Oct 23, 2007 | 10:45 AM
SRTpowa's Avatar
Now this could be another reason why there is no low end readings.
http://www.v6performance.net/forums/...ad.php?t=68133
I'm not sure how the autostick works entirely, but it may shift to a lower gear when you punch it, also causing a TQ spike. This could make it hard to get an accurate low end reading depending which gear you dyno in?
Anyway, if all you want is more top end HP, then the ASP kit looks like a good deal.
Old Oct 23, 2007 | 11:03 AM
jonnyangel04's Avatar
Originally Posted by AMGrasoul
Actually I heard that somewhere, on the subject of larger crank pulleys. That was assuming weight difference on an NA engine. I just double checked it, the torque decrease does seem abnormal after all...
Unfortunately when I did my dyno it was a dyno drag day (you line up and they do a dyno one after another for $20 for 3 runs, monthly event) and they said mine needed a different adapter or something like that to measure torque, and asked if I could live without it so they could get through more cars... so I don't have a torque reading, just HP.
Is this ... 430 ... from mbworld ?? If so I have dibs.
Old Oct 23, 2007 | 12:10 PM
Chi-Town SRT/6's Avatar
Least expensive is ASP Racing. They have an 14% overdrive pulley with Dampener (same as renntech and EVO) for $970 - No ECU tune - keep the stock belt - easy bolt on (with a big torque wrench).
http://www.aspracing.com/frame.htm
Ask for part number 331380 (not listed on their website) Here are the pics they sent me.
Then there is a new kid on the block (leading edge technologies) that makes a 20% Overdrive Pulley - but you need a new belt and I found no way to contact him, email, snail mail, phone or fax. Heck I can't even find their website anymore.
And then there is EVO - similar to Renntech - they offer a pulley kits with and without the tune - and with a harmonic dampener and without one.
http://www.evosport.com/product/default.aspx?catid=317
Scroll to the bottom of the page for the kits for our engine.
Good luck and let us know what you decide and how it works out.
Just ordered the ASP pulley above...will be here thursday.
Old Oct 23, 2007 | 12:31 PM
BrianBrave's Avatar
<--- Huge Horsepower
You Mad Dog!
Old Oct 23, 2007 | 12:40 PM
You Mad Dog!
guide me through this install...will I have to take any of the belts off or is this a 30 minute job?
Old Oct 23, 2007 | 01:18 PM
BrianBrave's Avatar
It pretty simple - I have the instructions from ASP at home and will PM them to you after work. Plus you should get a these when your order arrives.
Only special tools you will need are a breaker bar or impact wrench and a torque wrench capable of 200 ft pounds (If I recall the setting is 180-185 ft lb) and some lock-tite if your a lock-tite kinda guy.
Take a picture of the belt and how its routed, amazingly the SRT does not come with a belt diagram under the hood. The two other pulleys are pretty simple to R&R.
Old Oct 23, 2007 | 01:23 PM
I'm assuming you have this pulley...how was the power gain from it?
Old Oct 23, 2007 | 02:25 PM
ShawnQ's Avatar
Chi-Town,
BrianBrave does not (yet) have the pulley - just researched it well.
Steve Hellums sent me a how-to for installing the Renntech pulley and ECU.
If you are interested in it, I'll forward you the PM. He said it took him 4-5 hrs, but he took his time and was 'looking' at a lot of the parts on the car to figure out what all this thing has and how it works. Without swapping the ECU, you should save some time...but it isn't a 30 min job.
SQ
Old Oct 23, 2007 | 02:28 PM
Dave McGuire's Avatar
If and when your ready to sell the ASP kit, I am interested.
Old Oct 23, 2007 | 04:14 PM
hawksview's Avatar
Make sure you do a follow up for us. I'm interested to see how this pulley system performs without a flash.
Old Oct 23, 2007 | 04:24 PM
ASP pulley kit for sale.
If and when you offer the ASP pulley kit for sale, I'm interested.
Old Oct 23, 2007 | 06:29 PM
SRT6 Dan's Avatar
Banned
I just made my own pulley set... and assuming I can tune around the custom pulley I'll have an ASP pulley kit for sale. I'll know by the weekend. I sent my ECU in to powerchipgroup with my pulley specs, but it still seems to be running rich, even though I have the new pulley. I think the head work and headers have altered it enough where I need another tune, because the MAP signal is much higher, which results in dumping more fuel. I'm going to try to correct this myself with a piggyback fuel controller, I'll keep you posted
The ASP kit is nice because it retains factory belt. The pulleys I made produce a 24% overdrive on the supercharger, and it took me nearly a month to track down a belt that would fit it. The other nice thing about ASP is it requires no tune, it works with factory ECU settings.
let me know if you decide to sell the asp pulley. thx.
Old Oct 23, 2007 | 06:37 PM
I will have a full write-up as well as some 1/4 mile times. My plan is to install thurs and take her to byron on saturday.
Old Oct 24, 2007 | 10:33 AM
AMGrasoul's Avatar
This isn't 430, this is rasoul. Go figure huh?
But I believe he is also selling his ASP kit as he's going with the LE kit instead.
Old Oct 24, 2007 | 10:59 AM
AMGrasoul's Avatar
And to the many who have replied or PM'ed me with interest in my pulley... I'm still nervous about letting go of it right now until I'm more comfortable with keeping the one I made. Honestly it might be overkill, and I definitely need a tune with it. So I'm going to see if it's feasible for me to keep the new one before I get rid of my ASP pulley. For those wanting it by this weekend... sorry. :|
My car should be back together tonight or tomorrow and I can test out the new headers and pulley together and then use my Apexi to tune. Should be next few days, saturday at the latest, before I know whether or not the new pulley will work out for me.
Check out my separate post with info on the one I made.
Old Oct 24, 2007 | 11:24 AM
yeah he is still waiting on parts and I am still waiting for the pulley no hurry how much bigger is your pulley over the LE pulley ?
Old Oct 24, 2007 | 11:31 AM
  #38 (permalink)
AMGrasoul's Avatar
LE is 185mm i believe, and my new one is 192mm.
Here are the specs of mine: https://www.crossfireforum.org/forum...ad.php?t=18961
Old Oct 24, 2007 | 11:46 AM
  #39 (permalink)
boohooramblers's Avatar
Hey man - nice work you are doing and I assume you have done the research, but...
Would you think you are a little too close for comfort to the 20,700 rpm limit of the supercharger with a 192mm pulley?
Old Oct 24, 2007 | 11:51 AM
  #40 (permalink)
AMGrasoul's Avatar
Originally Posted by boohooramblers
Hey man - nice work you are doing and I assume you have done the research, but.....
Would you think you are a little too close for comfort to the 7,000 rpm limit of the supercharger with a 192mm pulley?
Yes. Hence the discomfort I was referring to earlier, and the reason I'm keeping the ASP pulley kit for now. Glad someone understands why I'm not letting go of it just yet.
The reason I'm comfortable enough with trying it out is because of the magnetic clutch... offers a little more safety than just having a pulley straight up bolted to the blades.
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Sep 26, 2015 10:21 PM
