Secondary y-pipe sensor popped out!
Old Jan 5, 2008 | 08:39 AM
240M3SRT's Avatar
Unhappy Secondary y-pipe sensor popped out!
Im referring to the aluminum y-pipe that has a sensor in it. It is after the supercharger so it is under boost.
So im driving down the street and pull up to a stop sign when the car starts acting funny. First, the idle raises to 1000rpm. Then it starts to fluctuate back and forth between 1000rpm and 2000rpm and the CEL comes on. When i accelerate on the gas i notice a "swiiiish" sound. From previous turbo car experience this sounds like a boost leak...and sure enough it is. When i pop the hood i intitially expect one of the secondary y-pipe hoses has come loose. Upon closer inspection i see that the little sensor has actually popped out of the y-pipe. I push the sensor back down, close the hood, and the car drives fine.
Has this happened to any of you yet? There is a little plastic clip that holds the sensor down in the casted aluminum housing, actually it may be part of the sensor, it was hard to see. IMO its very cheezy and prone to pop off at any time, especially in a race when your under boost. If this happens again, im going to look into the possibility of buying a threaded sensor, which will be hard if not impossible to find one with the same connector. Id really hate to have to splice another connector on, considering im not sure how finniky the ECU is to the resistance of the wire chaging due to the splice/solder. In other words....i REALLY, REALLY, hope it doesnt happen again.
Once more thing, do you guys know if this car automatically pulls timing, or goes into limp mode when the CEL is on? Becuase it seems a hair slower now. I have not cleared the code yet nor do i know if a generic scantool will work or if i need to take it in to Chrysler.
Comments?
Old Jan 5, 2008 | 08:51 AM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: Secondary y-pipe sensor popped out!
Comments?
With the CEL on for this reason - the ecu will pull timing and will need to be reset. My sensor whent bad and I had it replaced under warranty.
Old Jan 5, 2008 | 10:06 AM
240M3SRT's Avatar
I just called the Chrysler service mgr and he said after so many key cycles the CEL will turn off. I dont know if he knows what hes talking about, or if the ECU will truly be back to the way it was so it doesnt pull timing.
Old Jan 5, 2008 | 10:27 AM
srt6_crossfire's Avatar
Comments?
YES! :-( in the middle of a road race..
Lost power while going 120+ mph with another xfire behind me having to do some serious maneuvers to avoid hitting my a$$ and both of us go up in a ball of flames.. all in the name of fun... haha
Old Jan 5, 2008 | 11:48 AM
jjkiii's Avatar
I may be wrong but I think I read somewhere that disconnecting the battery - letting power drain - will rest ECU back to factory....it may have been for a different type of car...
Old Jan 5, 2008 | 01:25 PM
240M3SRT's Avatar
Wow, thats dangerous...has it ever happened again or did you rig up some kind of failsafe?
BTW, my service mgr was showing me how to turn off the service interval message(wrenches) and when he started the car back up the CEL was gone. He said it was just coincidence, and that after the car cycles through the warming up and cooling off process enough it will turn off automatically if the problem is not present.
Old Jan 13, 2008 | 11:30 AM
hasn't happened since and no special rigging, i just check to make sure its seated from time to time.
i think it popped off during the run when i didnt realize my hood was not closed all the way and running at high speeds (which i got meat balled for) and combined with running over rumble strips.
rampntlion
21
Feb 11, 2019 08:18 AM
RacerXofFL
Sep 15, 2015 05:00 PM
caseydeankopp
Sep 13, 2015 07:25 PM
81's
Sep 13, 2015 04:34 PM
bobbie
Sep 12, 2015 12:49 PM
