Do you change your oil after garaging for the winter?
Old Mar 13, 2008 | 03:59 PM
sherry7's Avatar
Default Do you change your oil after garaging for the winter?
Just wondering, do you guys have your oil changed having having your car garaged for the winter?
My baby has been in the garage since mid-November, and I hope to get it out in the next day or two. It has around 4300 miles, and I'm still working on the original oil change that the dealer did when I bought it. (It was a 'new' SRT with 16 miles that had been warehoused.)
So...should I get the oil changed, or am I good to go until 7000 miles? Thanks for your opinions.
Old Mar 13, 2008 | 04:05 PM
The Toy's Avatar
Default Re: Do you change your oil after garaging for the winter?
If your still running on the factory oil, I'd certainly change it. Even after letting it sit the winter, I'd still change it. Make sure they reset the computer so it won't show to be changed in a few thousand miles.
Old Mar 13, 2008 | 04:28 PM
I would change it since it's still original. Probably not if you had changed it before storing.
I'm wondering what those do at first start up when the cylinders are dry after sitting for so long without starting? I run mine once a week or so.
Old Mar 13, 2008 | 04:29 PM
crossfirefun's Avatar
I change mine every spring after it's long winters nap. Cheap insurance to make sure it didn't get contaminated over the winter.
Old Mar 13, 2008 | 04:56 PM
RPM's Avatar
RPM
Moderator
Everything I read said to change oil before storage.
Old Mar 13, 2008 | 04:57 PM
sherry7's Avatar
Thanks for the opinions guys. I guess I'll go ahead and get it changed since it has 4300 miles on it and it's been sitting all winter.
Just to clarify, the dealer did change the oil when I bought it...so I haven't been running it all of this time on some nasty oil from 2005.
Old Mar 14, 2008 | 04:07 AM
crossfirefrank's Avatar
I changed mine before storage and don't start until spring. If you start it once a week / month make sure it comes up to normal running temperature before shutting off.
Old Mar 14, 2008 | 02:59 PM
waldig's Avatar
Wink Re: Do you change your oil after garaging for the winter?
In my mind oil is cheap and I still change every 3000 miles and never look back. If I stored the car for a while I WOULD ALWAYS CHANGE BEFORE STORAGE TO KEEP FROM ETCHING THE BEARINGS WITH OLD ACIDS.
Sitting still adds no crud, if you want add a small heater under the oil pan with a thermal switch to cut in where you like, 40 degrees. That would be over kill. My 6 pack 440 never gets started without oil pressure first. THATs important to float the bearings after a long snooze. An oil pressure accumulator is easy to add or as I did, make.
Waldig
Old Mar 14, 2008 | 11:23 PM
miltownsho's Avatar
Usually yes, with this car I did not though.
Old Mar 15, 2008 | 09:41 AM
Goldwing's Avatar
I change the oil in my roadster before storing it for the winter. No need to change in the spring since Mobil1 is pretty stable. I do start it every 2-4 weeks and let it warm up - sometimes drive it around the neighborhood if the roads are dry - but that doesn't generate much in the way of contaminants given 8.5 quarts of oil. Same plan for the SRT6.
I am careful not to rev it when starting nor until it warms up.
Old Mar 15, 2008 | 10:34 AM
Hangman's Avatar
As others have mentioned. Always change your oil BEFORE storing your car.
Old Mar 16, 2008 | 03:38 AM
sherry7's Avatar
Thanks for the replies everyone. I made an appointment at the dealer to get it changed this Friday. Next winter, I will definitely get it changed before storing it for the winter.
Old Mar 16, 2008 | 10:15 AM
Who RU's Avatar
sherry7, If your taking it to HILLVIEW MOTORS let me know how they treat you............
Old Mar 16, 2008 | 01:30 PM
sherry7's Avatar
Hi, actually that is where my hubby made the appointment at. He talked to the service mgr, and asked if they had any X-fire trained mechanics. The service mgr replied, that yes, ALL of them were. Doesn't that seem odd? I read on here once that they had sold over 100 X-fires, but it still seems unlikely that they would go through the expense of training all of their mechanics.
I'll let you know how it works out. He couldn't even get an exact price, the service manager just said 'somewhere around $100'. Hubby replied, 'is that closer to $100 or $200?', and she replied, 'closer to $100'. I'm going to call back this week and try to get an exact price, because there is no reason they shouldn't be able to give one on a standard thing like an oil change. Hubby is too docile when talking on the phone, but I can be a real *itch if I need be, lol.
Old Mar 24, 2008 | 07:33 PM
sherry7's Avatar
Hi Who RU, just to let you know....I ended up cancelling the appointment at Hillview Motors and taking it to Smail Mercedes-Benz instead. The receipt is out in my glove box, but I believe the price was $118 plus tax. It seems like they did a good job, and I was in and out in about an hour.
BTW, the service guy at the Mercedes dealership really liked my car. He gave me a little history lesson on how in was based on the SLK, etc. Then he told me how much power it had, and to be careful not to let it "get away from me".
Old Mar 24, 2008 | 07:54 PM
BrianBrave's Avatar
<--- Huge Horsepower
And Filter
SOP!!
Old Mar 25, 2008 | 09:24 AM
Who RU's Avatar
sherry7, Thanks for the update.
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
sittininthesun
Aug 24, 2015 10:47 AM
waldig
Aug 14, 2015 01:02 PM
chturner
Jul 24, 2015 04:47 PM
