Weird noise from engine at idle
Old Sep 14, 2008 | 11:03 PM
mousegu's Avatar
Default Weird noise from engine at idle
I'll post a sound clip soon so you can actually hear it, but I was hoping someone might have an idea what this is before I go to the trouble.
When my car is sitting at idle there i a weird whistling noise. Not very loud, but just enough to bother me.. Sounds like a belt pulley needs to be lubed or something.
Anyone else ever experience this?
Thanks!!
Old Sep 17, 2008 | 07:48 AM
Montana Crossfire's Avatar
Default Re: Weird noise from engine at idle
Whistle sound leads me to think it's a small air leak from your intake...
mike
Old Sep 17, 2008 | 07:53 AM
Stogey's Avatar
Is it just at an idle or does it get louder when the supercharger kicks in ? A whistle noise makes me think vacumn leak !
Just my Dos Centavos
Old Sep 17, 2008 | 10:40 PM
mousegu's Avatar
Hmmm possibly. I had a vacuum leak on my Jeep, and this sounds very different from that. A rhythmic squeak might be a better way to describe the sound.
Ill get a sound clip on soon.
And I can't hear it if i'm not idling.
Old Sep 19, 2008 | 03:06 AM
mousegu's Avatar
Ok here is the sound clip.This was recorded with the hood open right in front of the timing belt (where it seems the noise is coming from).
It doesn't sound that loud outside of the car with the hood shut or I'd be really upset. Its just slightly audible normally, but I recorded it this way so you could hear it better.
Again it sounds like its coming from the timing belt area, and its only at idle as far as I can tell.
Any ideas?
Old Sep 19, 2008 | 03:45 AM
Stogey's Avatar
Geez Mouse ! Sounds like a belt squealing !!!
Remove your accessories drive belt and start it up again to better isolate the noise. It will be fine to run this way for a few minutes.
You may need to clear a few fault codes after re-installing the drive belt. Worst case....idler, water pump, SC, pulley bearing.
Keep us posted !
Old Sep 19, 2008 | 04:04 AM
robby363's Avatar
It might be the idler pulley. I had one go bad on another car I owned and the noise does sound like it. The bearings in it start getting noisy before it seizes up.
Old Sep 19, 2008 | 06:34 AM
Bulldogger's Avatar
That's not a belt squeek, bearing noise. Start with the easiest stuff first ilde bearing and tensioner. Next water pump and supercharger.
Old Sep 19, 2008 | 01:04 PM
Stogey's Avatar
Mouse ! Anything yet ? Inquiring minds want to know !
Old Sep 19, 2008 | 01:08 PM
theskipper's Avatar
Drip some water on the belt this will quiet the belt if its the problem but I also think its the idler pulley
Old Sep 19, 2008 | 06:40 PM
mousegu's Avatar
Sorry guys.. At work all day. Would a dealership fix this under powertrain warranty? I just don't have time to do it myself.
BTW I'm at 56k miles, more than any else I believe. So i hope this isn't i anyone else's future.
Old Sep 20, 2008 | 11:51 PM
kldiet's Avatar
http://www.youtube.com/watch?v=ehxL0JaYM9A
Take a listen to this and see if yours sounds like this. See the Supercharger Noise thread I have posted. Your are listening to SRT6 with a new pulley bearing and idler pulley.
Old Sep 21, 2008 | 02:51 AM
crossfirefun's Avatar
With 56000 + miles I would check the alternator bearings also.
Old Sep 21, 2008 | 08:45 AM
maxcichon's Avatar
At a guess, I'd go with this one...
Old Sep 21, 2008 | 01:20 PM
Voyager's Avatar
there seems to be alot of "noises" coming from the front of the engine lately. i hope this isnt going to become TOO common
Old Sep 21, 2008 | 01:25 PM
thats a bearing noise....
Old Feb 23, 2009 | 12:18 PM
rodimus's Avatar
Did you ever get this fixed mouse?
I think I'm having a similar issue.
THANKS!!
Old Feb 23, 2009 | 02:37 PM
240M3SRT's Avatar
I had a leaky intake manifold gasket that whistled, but it was loud and the engine idled poorly. Yours is probably the idler pulley as mentioned before.
Old Feb 23, 2009 | 04:41 PM
PA/XFIRE's Avatar
Ditto!!!!!!!!!!!!!!!! ILLCYA
IGot2P
Jul 26, 2025 12:40 PM
skeet370
May 15, 2018 12:57 PM
massanu
18
Nov 23, 2015 08:52 AM
Snake Eyes
Sep 28, 2015 08:55 PM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
