Still need oil pressure gauge solution...
Old Oct 9, 2008 | 02:50 PM
MikeR's Avatar
Default Still need oil pressure gauge solution...
I am still looking for a solution to install my oil pressure gauge. I may have a location for the sensor thanks to Splinter. But I still need to find a pressure sending unit.
I did find two on Amazon, but not sure if they will work for our engine.
Sunpro CP7577 and AutoMeter #2242.
Any info on suggestion or experience would be appreciated.
Thanks,
MikeR
Old Oct 9, 2008 | 03:16 PM
jonnyangel04's Avatar
Default Re: Still need oil pressure gauge solution.....
Thanks,
MikeR
TVT will be able to help with this, I believe he is going to be selling an install kit along with a defi sending unit. The oil pressure sending unit that comes with our gauges will work just fine, it is just a matter of plumbing you have run to get space. HEre is TVT's Kit something similar can be made it is just a matter of finding the fittings. Here is a site that TVT has recomended for us and our fitting. They can be very usefull finding the right sizes is the trick.
http://www.anplumbing.com/shop/index...&dept=Aluminum
http://cgi.ebay.com/ebaymotors/JOES-...mZ230167181256
Old Oct 9, 2008 | 03:59 PM
TVT_DESIGN
Guest
Posts: n/a
Making a kit has proved nearly impossible as it doesn't solve the original issue of tapping into the Oil Filter holder.
You will need:
2, 1/8" NPT Male into 1/8" NPT Female
3" long tube with 1/8" NPT Male
That's it then just screw in the sending unit.
You will also need a 46mm or 1 7/8" ratchet to remove the oil filter housing.
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
