Driveline thump solved
Old Mar 18, 2020 | 03:58 PM
  #41 (permalink)
Default Re: Driveline thump solved
Originally Posted by 93Snake
The Chrysler dealership is telling me that our carrier bearing is bad and needs replaced. The quote they gave me was $2100 "because it is all together and they can't just order the bearing". Is this something that could be handled at home or am I better off buying the part myself and having a shop do the work?
forget everything you just said go to needswings.com order the bearing ,,remove your drive shaft,,,,,,, with your hands (no tools needed replace the centerdriveshaft beaeing and boot),,,,,,, the drive shaft has notches on it for alinement and balance put every thing back together..
https://www.crossfireforum.org/forum...ght=driveshaft
Old Mar 18, 2020 | 05:10 PM
  #42 (permalink)
Jim, you must have the strongest fingers in the world if you can remove a driveshaft without tools
Old Mar 18, 2020 | 05:20 PM
  #43 (permalink)
LOL,,,blue that one didn't I , i edited it to show remove the boot/center bearing,,,most of the time they are loose enough to push off by hand. ofcourse after the drive shaft is out.
88stevie
19
Jan 21, 2026 01:46 PM
Oct 1, 2015 01:42 AM
Abaton6
Sep 24, 2015 10:14 PM
davidc90
Sep 6, 2015 10:37 PM
toob
Aug 19, 2015 07:31 AM
