Convertible Top Problem
Old Mar 15, 2009 | 12:32 PM
LEXSKY's Avatar
Default Convertible Top Problem
Has anyone had any problems with the glass window separating from the top? Does anyone have any good ideas to reseal it using a good epoxy? Or any suggestions on a repair shop in South Florida that can fix it?
Old Mar 15, 2009 | 02:55 PM
calxfire's Avatar
Default Re: Convertible Top Problem
There's 3 or 4 different threads addressing this problem if you use the search function. Bottom line is that the window cannot be glued back on. The good news is that one member found a cheaper alternative to replacing the whole top. I believe you may be able to have a plastic window installed to replace the glass. Here's the link......https://www.crossfireforum.org/forum...***+separating
Old Mar 15, 2009 | 06:15 PM
RMADERMAN's Avatar
Yes. If you use the search button you will find out that most all Florida Roadster tops have had the window separate and replaced under warranty.
Is your XF still under factory warranty?
Old Mar 16, 2009 | 06:59 AM
ws6vert's Avatar
Seems to be too common. RECALL!!!
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
mike28117
Jul 17, 2015 01:59 PM
Bayukbros
Jul 17, 2015 11:21 AM
