Sound Clip (strange noise)?
Old May 13, 2009 | 05:31 PM
cross><hair's Avatar
Default Sound Clip (strange noise)?
Finally got around to hooking up a mic under the hood to capture the strange sound my car makes between 1500-2500 rpms. Before or after that range it's silent. You'll hear it in the audio clip- I even purposely modulate the throttle to exaggerate the sound starting and stopping.
Rob said it sounds like something rotating- possibly a pulley/bearing. Anyone else care to speculate. Thanks in advance.
http://www.gmelliottvideo.com/srt6noise.wav
Old May 13, 2009 | 05:39 PM
j-fire's Avatar
Default Re: Sound Clip (strange noise)?
whoa. that sounds strange.... i stay away from pulley upgrades.
hopefully it's nothing to serious.
Old May 13, 2009 | 06:34 PM
cruzinquick's Avatar
Sounds like something is rubbing. Check your belt, hoses, wires everything to see if something isn't back on right. It's there from start up. Do the hose trick and try to centralize the noise.
Old May 13, 2009 | 06:41 PM
velociabstract's Avatar
Are you talking about that thunk thunk that sounds like the tread of a tire flapping? I hear several noises that I can't identify. I could be a bearing but which one and why now? I would be exploring with a listening device to eliminate parts and pieces first and then remove the belt and check all the pulleys one by one. You may be able to tell spinning them by hand. (long shot) Sorry, I really don't know.
Les
Old May 13, 2009 | 06:48 PM
Bulldogger's Avatar
It sounds more like a resonance echo. Check for something moving against the intake tubes, or the hook up in the catch can, with the tubes look for vacuum leaks around the tubes where the rubber boots are. Doesn't sound like a pulley to me.
Old May 13, 2009 | 07:39 PM
BrianBrave's Avatar
<--- Huge Horsepower
Sounds like a really old song from the 60's called "Echoes" by Pink Floyd
Old May 13, 2009 | 07:44 PM
NeedsWings's Avatar
the noise was there before the latest big round of mods so all those can be ruled out, glen i just snet ya an email with a bunch of picture to get started with the diagnostics. can u get the noise at that rpm while in park? if so have someone sit in th ecar and hold the gas there while your under the hood checking around.
Old May 13, 2009 | 08:44 PM
Unfortunately no- it only does it while in drive between those aforementioned rpms.
I appreciate all the help and input everyone.
Old May 13, 2009 | 09:11 PM
BrianBrave's Avatar
Perhaps as the system is building up PSI - enough pressure is made and a leak is occuring. As PSI bleeds - the sound goes away and the cycle begins again.
There have been a few VIDs of folks having pulley/bearing issues and you can hear the grinding through the entire RPM range - your sound seems to start after the SC engages and has some time to build PSI. Just a thought.
With the car parked and at idle - spray liberal amounts of carb cleaner around the plenums flanges and listen for a change in RPM - one way to detect a leak..
Old May 16, 2009 | 12:33 PM
///SilverSaphRT6's Avatar
[quote=BrianBrave]Perhaps as the system is building up PSI - enough pressure is made and a leak is occuring. As PSI bleeds - the sound goes away and the cycle begins again.
With the car parked and at idle - spray liberal amounts of carb cleaner around the plenums flanges and listen for a change in RPM - one way to detect a leak..[/quote
Great mind right here folks.
Old May 16, 2009 | 02:04 PM
Squirrel Crusher's Avatar
I used the carb cleaner spray back in the early 70's. It's a time proven technic for vacumn leaks. Don't see that it would be effective for finding pressure leaks. Just my thoughts! But,Is it harmless to the teflon coatings of the NeedsWings Mani's? Squirrel Crusher
Old May 16, 2009 | 02:05 PM
NeedsWings's Avatar
the sound was there for you on the stock intake manifolds and stock gaskets before you install the new stuff, installing the new stuff made no change it that noise, i wouldnt spray your pretty new manifolds with brake cleaner as it will dull the finish.
loosen the belt and spin as many pulleys as you can by hand and see if you feel anything out of the ordinary
Old May 16, 2009 | 02:19 PM
BrianBrave's Avatar
If your SRT6 is in park and the engine at idle, then the supercharger is not engaged and the manifold/plenums will be under vacuum. Your boost gauge will confirm this.
If the finish is damage sensative to carb cleaner or other sprays, you can use a more risky procedure with propane from a cutting / brazing torch - or a BBQ Lighter (not lit of course) - same results but with greater risks from spark......
Let us know what you discover....
Old May 16, 2009 | 03:09 PM
Thanks Brian for the tip that the supercharger want engauge in park while running up the RPM's. Squirrel Crusher
Old May 16, 2009 | 04:33 PM
LantanaTX's Avatar
An automotive stethiscope would come in handy to find this. Another old school trick is get a really big screw driver and place the handle to your ear while touch the metal end in suspect areas. when you find the source it will be very loud in your ear. This is also an easy way to find a worn pulley bushing. It does sound a little like the clucted s/c pulley but you also have one if these on the a/c compressor as well.
Old May 17, 2009 | 07:09 PM
These are all good suggestions however keep in mind the sound only starts at 1500 rpms and fades away after 2500 rpms. This makes it much harder to isolate the noise considering it only happens when the car is in gear and moving.
I'll have Chris's brother try what Rob suggested when it's in his shot to get the Super Cooler installed. If, for the sake of argument it's a bad idler pulley from the ASP 178mm kit how would I go about replacing it? TIA
Old May 17, 2009 | 07:27 PM
Email ASP, they helped lotus with his. They emailed me back right away and said they have never had one fail. lotus' idler idler bearing was completely rusted. Or just replace the bearing. You can also get a smaller belt and see if you can reroute one pulley at a time to see which if any eliminate the noise.
ty_ty37
Jun 27, 2024 10:42 AM
TerryR
Dec 13, 2019 03:27 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
brandoni
Sep 30, 2015 07:48 PM
