Camber issues
Old May 20, 2009 | 02:00 PM
j-fire's Avatar
Default Re: Camber issues
Originally Posted by Montana Crossfire
Just a thought, your not using your SRT to haul concrete or sod are you?
I've seen alot of cars destroyed this way
Mike
definitely no. i drive her very hard quite a bit, but only in a straight line. i never push her hard through the twisties(which would be a more likely culprit.) it's just driving me nuts! i've had to reset the camber 3 times!
Old May 20, 2009 | 02:11 PM
BlUEMDsrt6's Avatar
Maybe you just got a faulty camber kit? Try switching to camber bolts out front and see if that works for you. Its cheaper than buying another KMAC kit.
Old May 20, 2009 | 02:20 PM
j-fire's Avatar
good idea:
part numbers please
thanks!
Old May 20, 2009 | 05:46 PM
Jeff Cobb's Avatar
Originally Posted by j-fire
good idea:
part numbers please
thanks!
"4 202-330-01-18 parts kit" cost me $15 each.
BrianBrave posted photos on this thread:
https://www.crossfireforum.org/forum...amber-kit.html
Old May 20, 2009 | 08:16 PM
srt6's Avatar
Ok, I am sending the car in on Tuesday to a well respected alignment specialist. I will keep everyone posted and appreciate the insight thus far.
Old May 20, 2009 | 11:25 PM
Marine05's Avatar
Camber bolts will only give you about .5 degrees adjustment. I believe K-Mac Front Camber Kit can give you 1.75 degree adjustment.
Regards,
Glenn
Old May 21, 2009 | 08:02 AM
Steve Hellums's Avatar
When I installed my Eibach springs I used the Chrysler camber correction bolts in front & the K-MAC kit in the rear. It threw toe off in front & back so bad you couldn't hardly hold the car on the road. When I took it to the dealership to have a 4 wheel alignment, all they had to adjust was the toe. The front was right on the money as far as camber, and I had the back on one side just a hair off on camber. I had use a 2X4, level and a tape measure to adjust the rear K-MAC kit when I done the install. But after time has went by I think the front spring has settled some and need raised about 1/4".
ty_ty37
Jun 27, 2024 10:42 AM
UNDER PSI
Nov 1, 2015 09:39 PM
Reliableron
Oct 17, 2015 10:19 PM
bobbie
Sep 12, 2015 12:49 PM
MickeyNasty
Sep 6, 2015 08:29 PM
