belt wrap question
Old Jul 11, 2009 | 11:53 AM
Montana Crossfire's Avatar
Default Re: belt wrap question
I am just wondering If you haven't changed any Pullies as of yet, why are you wanting to run a belt wrap kit???
Mike
Old Jul 11, 2009 | 01:22 PM
32krazy!'s Avatar
Originally Posted by tighed1
Dude!
I don't know about the SLK but on the SRT taking the fan out of the car (thus out of yer way) takes all of one minute. That would give ya extra clearance to work.
Not sure which torx you are talking about. The tensioner?
On my cars I use a 15mm box wrench and use the nut that is also on the tensioner to release the tension. Don't yank on it as you will loosen the bolt. Just apply smooth pressure and the tensioner will pull back.
Let me know if this works for ya.
taking the fan out seems like a must do now!! yes the torx is the at the end of the bolt holding the pulley nut on. i was trying to get the leverage to open it up as far as possible to get the belt on as it slipped off.
by using the nut i was able to get the oem setup back on.
montana crossfire, i was originally going with a c3 pulley and the wrap. my deal with the pulley fell through so i figured ,why not? just install the wrap and be ahead of the game and maybe pick up a couple ponies in the process.
Old Jul 25, 2009 | 02:58 PM
SRT-6 Steve's Avatar
Any updates on this thread? Any issues to running a grooved pulley on the back of the belt? I don't think I would do that. If I am not mistaken, the tension will be the same applied by the tensioner no matter where you are within the range it adjusts to unless you are bottoming out so I am not understanding a few of the comments?????
Steve
Old Jul 25, 2009 | 03:05 PM
32krazy!'s Avatar
Steve
the issue was never about the grooved pulley on the backside of the belt. i was unable to install the wrap with the stock s/c pulley. it put to much tension on the pulley tensioner. i must have been bottoming out the tensioner by adding a pulley and not reducing the size of the s/c pulley. i wont try this until i have a c3 or maybe a crank pulley as all the c3 pullies i tried to buy were being sold by dishonest folks ie: rt189 or flashylights
Old Jul 25, 2009 | 03:20 PM
I understand. I have had the C3 pulley since they first came out and am very pleased. I have the stock crank pulley and it seems to work very well with the C3.
Old Jul 25, 2009 | 08:21 PM
32krazy!'s Avatar
i have been looking for a c3 pulley. i had deals on 2 of them and the bums couldnt keep up their end of the deal. so the search is back on. the good thing is in stock form i can 150 mph!!!
Old Nov 29, 2010 | 12:11 AM
lacerdaschoon's Avatar
I got my belt wrap kit instaled today but the mech wasnt sure exactly how to do it and ended up applying it to the idler instead of the tensioner? Does this make sense to anybody and is that right?
Old Nov 29, 2010 | 12:56 PM
MikeR's Avatar
If you got the NW kit, it has a pulley for the idler and the tensioner.....
Old Nov 29, 2010 | 04:01 PM
This is the C3 Belt slip kit
Old Nov 29, 2010 | 06:51 PM
32krazy!'s Avatar
is it a code 3 kit? i ended up having rob build me a pulley saver kit for the c3 setup and i have inc. belt wrap and the bearing failures i was having have dissappeared. best kit out there!
Old Nov 30, 2010 | 10:49 PM
I have a code3 pully and bought a belt wrap kit from them ages ago. I finaly got it instaled and it deffinately feels like its making a difference. I wish i had done the same as you before buying this kit but i may look into getting Rob to hook me up as well at some point in the future.
Is your kit anything like the code3? It seems as though i just have an added pulley that fills inbetween the space of the idler and sc pully to give it more grip?
Old Dec 1, 2010 | 07:04 PM
32krazy!'s Avatar
if you look at robs thread on the pulley saver kit mine is identical to the others except its made for the oem crank and c3 pulley. the idler next to the s/c is eliminated and a new pulley 100mm is located above the alternator. the other idler is also changed to 100mm and the tensioner pulley remains 90 mm but replaced with a better and easier to obtain version. whole kit wrapped in a longer belt. since the install i have run my car hard as always and have not had a single bearing failure and i can log consistent 19 lbs boost on a 50* day
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
4drturbo
Oct 2, 2015 12:58 PM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
