Tensioner pulley
Re: Tensioner pulley
Originally Posted by tighed1
Believe its a Gatorback belt. Came with the car.
Also came with that 192mm crank pulley!
FYI - Professor Woody doesn't like the Gatorback belt. Seems to be working just fine on this application.
Brandon
on
1 Post
DJ
using your method, is it possible to get the belt back on with the 185 pulley? i know i can slide the belt off, but im concerned that even if i tighten the tesioner pulley so i can crank on it to give the system some play to slide the belt back on, it either wont be enough or the amount of cranking necessary will loosen the tensioner pulley bolt......thats why i was using the other bolt on there
