Pulley Saver Kit
Old Aug 18, 2009 | 01:55 PM
  #81 (permalink)
jturkel's Avatar
Default Re: Pulley Saver Kit
Originally Posted by Bubba89
I'm doing the same thing Tighed is to remove my belt and it works like a charm. I found that positioning the wrench so your pushing across to release the belt helps it from not loosening up, if you push down it tends to loosen every time. I used it to install the Tighed belt wrap kit coupled with my smaller supercharger pulley and 178 set up and it worked quite well so it should be able to work fine with the 185 install also.
Brandon
tried this. it works a little. but it will be impossible to generate enough slack slack in the belt to install the 185....i've tried.
Old Aug 18, 2009 | 02:21 PM
  #82 (permalink)
tighed1's Avatar
Since it was mentioned here, here is more info on the tensioner.
Available from Autozone for $122 or so shipped to you.
If you are looking for other sources here's a few part numbers...
ACDelco: 38174
Dayco: 305335, 89335, 89335FN
Gates: 38174
Goodyear: 49262
Mercedes Benz: 112 200 03 70, 112 200 09 70, 112 300 03 70
Old Aug 18, 2009 | 04:23 PM
  #83 (permalink)
32krazy!'s Avatar
ACDelco: 38174
Gates: 38174
Goodyear: 49262
i tried to cross reference the m/b parts numbers and it comes back fitting a 320 and a sl55. these are 2 different tensioners. autozone doesnt list any of these parts. were did you see the 122$ part?
Old Aug 18, 2009 | 05:17 PM
  #84 (permalink)
waldig's Avatar
Talking Re: Pulley Saver Kit
Iam doing a 185 and have used the bolt head and nut with success, the belt on my 185 IS NOT TOO TIGHT. Between the s/c and alternator I can push down the belt 1 or more inches with a finger with moderate pressure, (deflect the belt). Woody
Too tight kills accessories and their shaft bearings............
Old Aug 18, 2009 | 05:47 PM
  #85 (permalink)
32krazy!'s Avatar
thanx woody. jturkel will be glad to hear that.
MikeR sent me the simple solution. add a nut to the pulley nut as a jamnut! did it countless times on my harley. should have thought of it myself!!
Old Aug 18, 2009 | 06:14 PM
  #86 (permalink)
70GT6's Avatar
Search for part # 305335 at Autozone .. this one is a Duralast item.
Old Aug 18, 2009 | 06:26 PM
  #87 (permalink)
32krazy!'s Avatar
comes back as not available
Old Aug 18, 2009 | 06:29 PM
  #88 (permalink)
70GT6's Avatar
Strange - I have it. - did you click the link? and still nothing?
Old Aug 18, 2009 | 06:34 PM
  #89 (permalink)
32krazy!'s Avatar
yes listed as not available
went to the website part different part number for the slk32 tensioner. foto shows 3 mount holes. # 305354
ha! found the answer. autozone AND advance auto have the pulley tensioner for the slk32 and the slk320 reversed! the tensioners shown have pulleys which are not removable if im seeing the fotos correctly. im looking for the oem replacement and that raises the cost
Old Aug 20, 2009 | 11:09 PM
  #90 (permalink)
jturkel's Avatar
WOODY, you have a PM!!
edit: b/c i'm dumb
Old Aug 21, 2009 | 05:13 AM
  #91 (permalink)
ProjectMayhem's Avatar
Put me down for a pulley saver kit just ate my first belt at 19k.
Old Aug 26, 2009 | 09:05 PM
  #92 (permalink)
70GT6's Avatar
Rob (or anyone out there)
I got the kit today - but no instruction sheet.
Not that it should be too hard, but I would like to make sure to get it right.
Anyone email or post a copy?
Dan
Old Aug 26, 2009 | 10:41 PM
  #93 (permalink)
MikeR's Avatar
It should look like this.........
Old Aug 27, 2009 | 12:18 AM
  #94 (permalink)
NeedsWings's Avatar
link to instructions was in the email with the tracking numbers, im pm'ing it to you again now.
Old Aug 27, 2009 | 02:41 AM
  #95 (permalink)
70GT6's Avatar
Thank you!
Old Aug 27, 2009 | 08:10 AM
  #96 (permalink)
RPM's Avatar
RPM
Moderator
Put the pulley saver kit on last night. Everything has a 'heavy duty' feel and turned out very nice.
Thx.
Old Aug 31, 2009 | 12:59 AM
  #97 (permalink)
NeedsWings's Avatar
Here we are "going green"
the green hd belts arrived
Old Sep 5, 2009 | 06:36 PM
  #98 (permalink)
SRT6-Man's Avatar
Got the pulley-saver kit on today! So far so good! Now a few high speed runs, and see if any thing flys off!
Old Sep 6, 2009 | 08:03 AM
  #99 (permalink)
NeedsWings's Avatar
looking good, the only thing flying off would be your sunglasses and hat
Old Sep 17, 2009 | 06:15 AM
  #100 (permalink)
TemjinX2's Avatar
i just ordered mine..
