Sanity check on oil change interval
Old Oct 6, 2009 | 03:46 PM
waldig's Avatar
Wink Re: Sanity check on oil change interval
When I change my gently used oil, I re use it. Its great in my skid loader, 4 wheeler, riding mowers and mower. Its synthetic and been in longer than driven, so I get the use of it and the yard stuff gets the benefit of frequent changes too.
Woody.........and weed whip- blower everything but the chain saw.
Old Oct 6, 2009 | 03:51 PM
distantpulse's Avatar
Default Re: Sanity check on oil change interval
Originally Posted by ZAHANMA
Well, I'm off Monday for Columbus day... how about Monday night we hit up the shop...
If I leave work by 4 and get there by 5:15-5:30, is that cool? I might be able to swing that. I will come in a little early Monday....
Old Oct 6, 2009 | 04:01 PM
Marine05's Avatar
The FSS is pretty good. As a general rule though I would say change the oil every 6 months or 5,000 miles, whichever come first. In your case you said you changed the car last fall and drove the car less than 1.000 miles this summer. Looks like it has almost been a year then so I would definately change the oil.
Old Oct 6, 2009 | 04:18 PM
ZAHANMA's Avatar
That will work... we can take it offline, PM me about it and we'll figure it out. I dont have any plans as of yet...except to be off next tuesday afternoon to go to the track...this is why Monday is the best idea...then we can get everything good to go and hit the track tuesday.
Old Oct 8, 2009 | 11:11 AM
Bladecutter's Avatar
Originally Posted by Goldwing
Yes, I'm a little cheap, but also I don't want to throw out perfectly good oil (think green). I changed the oil (Mobil1 0W-40) last fall and drove the car less than 1000 miles this summer. Not raced, not dusty conditions, just gently around town and some highway. The oil on the dipstick still looks golden, not dirty. Given I'm using a top-rated synthetic, is it really mechanically necessary to change the oil? (Please don't tell me it's cheap "insurance"...I really want to know if synthetic oil breaks down with age or is good for a couple years.)
The engine oil is good for two years in your oil pan.
The biggest things to worry about are water condensation building up, and gas dilution.
So lets look at these two items separately.
Fuel dilution of the engine oil:
It occurs when the engine is started up cold, when the computer adds more fuel to mixture to get the engine to warm up quicker, and idle better when cold. If you take one poster's advice and just start the car up every once in a while, you are guaranteed to increase the amount of fuel in the oil, and that's the worst possible thing that you can do to the engine oil. You are better off just letting the car sit for long periods of time than to occasionally run the engine cold.
Water condensation:
Water is in the air as humidity all the time.
There is more in the air in Florida than there is in Arizona.
That said, your engine is a fairly air tight contraption, due to emissions regulations.
They don't want the oil vapor getting out of the engine into the atmosphere, so the engine is built with an air tight PCV system. So basically, unless you leave the car parked with the oil cap off, or unless you altered the hoses on the engine in a bad way, you shouldn't get very much condensation in the engine oil from normal circumstances.
The great thing about water is that it boils at a much lower temperature than engine oil does. So the easiest way to get rid of it from the oil is to simply drive the car until the oil is good and hot. When the water boils, it gets sucked into the PCV system, and the engine burns it with the fuel, and you no longer have water in your oil.
A simple 50-100 mile drive on the highway should eliminate all of the water in the oil, unless you poured in a gallon of it.
Gasoline is a little harder to boil out of the oil, simply from the fact that you would have to get the oil considerably hotter. You would actually be better off draining the oil out of the engine, putting it into a large lobster pot, and using a liquids thermometer, bring the oil up to about 300 degrees, and keeping it there for about 30 minutes.
You could actually do the same for water dilution, but then you would only need to bring it up to about 225 degrees.
So no, you don't need to change your oil because its a year old with only 1k miles on it.
If you can take the car out for a good long drive, that will suffice.
BC.
Ralph289
Sep 12, 2021 11:15 AM
PNA
Nov 12, 2020 04:44 PM
xfClifford
Aug 3, 2015 11:03 PM
Crossfireconv08
Jul 30, 2015 12:11 PM
skeet370
Jul 18, 2015 01:02 PM
