Zeitronix installed...
Old Nov 20, 2009 | 07:34 PM
MikeR's Avatar
Default Zeitronix installed...
Okay, I finally got all the little things I needed to finish the cabeling and connect it to the ECU. Here are the pics of the install.
Electronics box with the RCM, ECU and BCM removed where theZeitronix cable will feed through the bottom of the box into the cabin....
Here is the cable feeding through(black cover)....
Cabel coming into the cabin behind the glove box...
Installed complete and electronics re-installed....
And finally, all buttoned up and ready to plug in the laptop....
Now it's time to go play with it...
Old Nov 20, 2009 | 08:36 PM
Squirrel Crusher's Avatar
Default Re: Zeitronix installed........
My Zeitronix connection wire for the lap top plug in connection is hidden in the removable dash pannel you see when the passenger door is opened. The same pannel that houses the passenger air bag cut off. The two large plastic factory screws can be turned with a penny. Have you noticed the data logging when our SRT automatic's shift at WOT? You can keep the petal to the floor,but when our transmissions shift,the computer cuts the TPS way back during gear shift then to the floor again without you knowing. Maybe to keep the engine from over revving during shift,to help keep the tires from spinning so bad going into second or just for the Mercedes smooth shift?? It will also verify what Rob's has been warning us about concerning the 185 crank pulley. It will run dangerously lean at WOT. Where's our fuel upgrade Rob???? Squirrel Crusher
Old Nov 20, 2009 | 08:54 PM
MikeR's Avatar
I did a test run with it but the file didnt save right for some reason. It is raining like crazy here so I cant get too carried away. I just wanted to see how it looks. All of my dyno sessions show my AFR at around 12.7 at WOT. I may get the MAP sensor from them so I can have accurate boost numbers too. It will be a snap to add now.
I have a 181 so I dont have to worry about leaning out....... I am seriously thinking of add a meth kit too... Now I can monitor and see how it performs and what changes I might need to make...
Old Nov 20, 2009 | 09:02 PM
Bulldogger's Avatar
Fuel problems were solved along time ago on our cars.
Old Nov 21, 2009 | 04:45 PM
cross><hair's Avatar
That depends on who you ask.
Old Nov 21, 2009 | 06:55 PM
distantpulse's Avatar
Glen daddy!! You're back! you all tanned up? :P
Bulldogger's Avatar
Who states the pump doesn't work???
Old Nov 21, 2009 | 08:31 PM
NeedsWings's Avatar
beautiful pictures mike, thank you! yes that seems to be the preferred way into the cabin instead of using the rubber grommet under the battery tray. do you mind if i use some of those pictures to add into our writeup?
i have our zt2 brain in the same elastic pocket there on the pass side, makes it very easy to access the port to plug in different displays.
built on the bench right now, been playing with it today, i think its ready to go onto the car as soon as the last relay arrives. and here is the best part..... it will be run by the zt-2 brain that you guys already have im very excited with it.
Originally Posted by [b
Bulldogger[/b]]Fuel problems were solved along time ago on our cars.
please post up a datalog
Old Nov 21, 2009 | 09:22 PM
Bulldogger's Avatar
Dyno tuned by LET with 11.7 AFR straight across the board contact Jerry or Wayne. They saved the file.
Old Nov 21, 2009 | 11:20 PM
MikeR's Avatar
...do you mind if i use some of those pictures to add into our writeup?
Rob, no problem at all. They are in my gallery or I can email you the files.
Old Nov 22, 2009 | 10:28 AM
cruzinquick's Avatar
I think he's asking for a datalog from a run at least thru 3rd in a real nice cold air conditions. Do you have a datalogger that can record a run hooked up? The race date in december from mb world would be a great place to get a sweet datalog and dip into the 11's. The DA is supposed to be unreal.
MikeR once your weather gets better maybe you can post up a run through 3rd. You should think about hitting Sacramento on the 5th of December for our part of east vs west.
Old Nov 22, 2009 | 11:21 AM
Bulldogger's Avatar
I'm heading down to MIR 12/5 got rained out of ATCO. I have a Auterra DashDyno, that reads from the OBII port I'll data log when I'm down there if I can figure it out. The meter was loosing files and not downloading right. They stated I had to upload the lastest addition software which I did but haven't tried it since then. Besides Matt from the forum is heading down so I'm sure he'll have equipment.
Old Nov 22, 2009 | 05:14 PM
Were you able to get some DR's? That weather is like a once a year opportunity in your part of the country.
Old Nov 22, 2009 | 06:11 PM
Bulldogger's Avatar
No drag radials, still trying to lock down a trailer because the wife is going to attend. This way if something breaks we don't get stuck there.
Old Nov 22, 2009 | 10:46 PM
Definitely try to get some DR's or at least go half and half with Matt for a set to use that day. Mickeys or Hoosiers. With temps as cold as it will be, your stock tires will become dangerous. I've only ran once without my DR's, launched spinning a little but really spun when car shifted from 1st to 2nd. Went towards the center line and if the t/c yaw sensor? wouldn't have taken over I would have crossed and probably hit the wall. So be careful. I would compare it to your viper coming on hard in 2nd and losing all traction.
Old Nov 23, 2009 | 09:33 AM
Bulldogger's Avatar
thanks for the info I'll pm Matt and see if we can grab a set.
waldig
Oct 26, 2021 11:20 PM
NeedsWings
Mar 17, 2015 10:36 PM
dayjor
Dec 21, 2014 02:59 PM
dayjor
Feb 16, 2013 01:06 PM
MikeR
Apr 15, 2010 05:48 PM
