Oily puleys and belts.
Old Feb 3, 2010 | 11:48 PM
ProjectMayhem's Avatar
Default Oily puleys and belts.
I noticed that i seem to be getting a constant buildup of oil on all the pullies and the belt. I had to replace a belt this fall because the old one was slipping. There is nowhere to tell where the oil is coming from because its everywhere on the front of the motor. Not alot but enough to make a messy engine bay, and cause minor belt slip. I'm almost positive its leaking from the crank pulley/harmonic dampner, possibly the seal is leaking some and sligging this oil everywhere and making a mess. Has anyone with aftermarket crank pullies noticed excess oil on the front of the motor and touching your pullies noticed they are slimey and coated with oil?
PS: i get no oil spots when parking, maybe a drip if the car sits a few days, which just leaves me think its that seal on the crank pulley. I do have a 178 ASP so its possible the seal was harmed or maybe i should of put a new seal on with the new pulley. Rob have you seen this or any other track guys with crank pullies? or just **** owners .
God I butchered the thread title... 3 beers in 20 min after work and posting is to blame...
Old Feb 4, 2010 | 06:19 AM
waldig's Avatar
Talking Re: Oily puleys and belts.
I had to do my pulley seal and did a write up on it, take your time. Woody
Old Feb 4, 2010 | 08:21 AM
32krazy!'s Avatar
Default Re: Oily puleys and belts.
try this. clean the entire front of the engine. then use soft and dry deodorant in the spray can. cover the front of the engine with it.it will dry white. start the car and go for a run.
the soft and dry will absorb the oil and turn black. you can then trace it back to the source.
54
Jan 8, 2015 12:03 AM
hallfleming
Apr 12, 2013 12:53 PM
donoutwest
Jun 8, 2008 11:54 PM
bobs
Mar 24, 2006 10:45 AM
flugelboy
Dec 17, 2004 09:28 AM
