Extremely weird sound... Please take a look.
Old Aug 21, 2010 | 07:37 AM
Headlock's Avatar
Default Extremely weird sound... Please take a look.
So after I have been driving for say 5-10 minutes and I pull up to a red light I hear a knocking sound very similar to if someone knocks with thier knuckles on a 2 by 4. The sound happens every 8-15 seconds while idle. It sounds like it's coming from behind the passenger seat underneath. I see to only hear it at night but that's most likely because it is quite then. When I pull away no sound at all. Any input would be loved.
Thanks,
Nick
Old Aug 21, 2010 | 08:40 AM
maxcichon's Avatar
Default Re: Extremely weird sound... Please take a look.
Thanks,
Nick
Sound like either driveshaft or exhaust whacking on something.
Old Aug 21, 2010 | 12:58 PM
Buggin's Avatar
driveshaft center support bearing or driveshaft flex disk
my guess
Old Aug 21, 2010 | 01:18 PM
Likely only hear the drive shaft coupling if you were moving. He hear ist when stopped.
I'll put my money or an exhaust bracket failure.
franc
Old Aug 21, 2010 | 01:27 PM
Montana Crossfire's Avatar
Sounds like exhaust if it's happening at idle at stop cannot be Drive shaft.
I have seen vibration knocks in exhausts when at a slow RPM or when just barely letting out a clutch.
If you have the 6 speed from a stop low RPM put an ever so slight drag on the clutch and if there is a change in the "Knock" it's 90% exhaust loose.
Mike
Buggin's Avatar
My bad... I read too fast sometimes, I though he said while slowing down.
Exhaust hitting sounds like a possibility.
Old Aug 21, 2010 | 01:35 PM
see if you can take her somewhere where they have a car lift...get under there and shake your exhaust system back and forth to see if it is hitting something at idle.......
Old Aug 21, 2010 | 02:02 PM
Headlock's Avatar
Alright, will do. Thank you so much for the info. Any other possible ideas?
No stick here btw, it's my srt-6
Old Aug 21, 2010 | 02:50 PM
waldig's Avatar
Talking Re: Extremely weird sound... Please take a look.
Fuel pump and regulator is under pass seat and if it is vibrating just right................... Woody
Old Aug 21, 2010 | 02:55 PM
mr-lama's Avatar
Have you checked under the car for any kids that you may have accidentally run over and are trying to get your attention? That's a pretty common problem from what I hear.
Old Sep 1, 2010 | 02:38 AM
cudaman's Avatar
My vote: Exhaust hanger rubber bushing failing. Vibration squashes bushing too much and making metal-2-metal contact.
2nd vote: driver needs medication adjustment for schizophrenia so that he/she stops hearing noises and cars speaking to him/her in tongues.
Dec 2, 2015 12:49 AM
maxcichon
Sep 30, 2015 11:38 AM
eatmycrackers
Sep 23, 2015 09:08 AM
ala_xfire
Aug 16, 2015 09:45 PM
Xfirenewbie
Aug 11, 2015 10:12 AM
