Performance chip direct
Old Oct 28, 2010 | 01:20 PM
crazycrossfire's Avatar
Default Performance chip direct
has anyone heard of PCD(performance chip direct)they claim to have a chip for the crossfire that can save you 4-7 mpg and give you up to 60 hp gain for only $69.99. for N/A and supercharged models.
Old Oct 28, 2010 | 01:24 PM
BLACKSRT-6's Avatar
Default Re: Performance chip direct
I have beach front property in Kansas for sale, only $100 per lot!
Rip off crap.
Old Oct 28, 2010 | 03:45 PM
bmorgan's Avatar
They work great. After you get that, you may want to add one of these electric turbo chargers for $29.99 Electric Intake Super Turbo/CHARGER ALL MAKES/MODEL +HP. With this setup, you should be able to outrun a Lambo.
Old Oct 28, 2010 | 08:43 PM
mrphotoman's Avatar
you can get a Lay's chip for around $2.99 and it has similar performance results as the performance chip direct.
Old Oct 29, 2010 | 09:05 AM
Just what I thought. Thanks for your input.
Old Oct 29, 2010 | 04:09 PM
they really can be hard on you ya know? no chips....you have to have them tuned by a tuner, and there are only a few of those individuals out there.....read up on them....use the search...and punch in "tune"
or dyno tune....etc.....
Old Nov 8, 2010 | 04:05 AM
vpats's Avatar
Wouldn’t that be move of an electric supercharger, since it’s not exhaust driven? The theory is interesting and reminds me of the Dodge Charger boys of the late 50s who used an old Dodge Coupe, maybe a 46 model. They were running a 392 Hemi and had mounted a GMC supercharger in the trunk with piping up to the engine. The blower was driven by an auxiliary small engine, like a Briggs & Stratton. One of the advantages of this setup was they could begin the run with full blower output. The idea was that it would be "free" horse power, that is, it would cost the Hemi noting to run the blower (horse power) and get full benefit from the extra power.
I’ve often thought about a more sophisticated electric blower setup, not like this $30 job.
Old Nov 8, 2010 | 07:46 AM
I'm not sure how much power the supercharger can use up, but you will need the same amount of power from an electric blower. Twelve or even twenty four volts would not supply enough power. You would need a long electric cable and a huge blower and motor (say about 10 - 20 hp) to accomplish that.
At the drag strip you would need a suitable outlet of 400+ volts and a cable nearly a half mile long. The trailer with the blower, electric motor and drum for the cable on it would be a pain to drag around.
If you wanted to drive on the road the cable presents a huge problem, if they were to get popular the roads would be littered with cables and you would need a 4x4 to climb over them. Of course if you patented it, people would complain about tripping over your cable and you would be sued every day, the cost of the cable and picking it up all the time would negate the time saved getting anywhere fast as you would have to keep going back to pick up your cable and finding somewhere else to plug it in.
Old Nov 8, 2010 | 07:01 PM
vpats's Avatar
Which is exactly why I quit with "just thinking" about it.
Old Nov 9, 2010 | 10:49 AM
MetalMilitiaSRT's Avatar
These "performance chips" are just resistors for a computers electrical current. From what I read in the past, they trick your ecu into thinking the air is colder, thus more dense. The ecu then compensates by delivering more fuel. More fuel means bigger bangs in the cylinder which means more power. I also read that they wreak havoc on the electrical circuit. In the end, they are not worth it.
Old Nov 9, 2010 | 11:17 AM
What do ya'll think of this one?
X3 Performance Chip with O2 Sensor Control [40-50HP]
A friend of mine with a clk320 wants more power, does this look remotely legit?
Old Nov 9, 2010 | 03:35 PM
Thirteendog's Avatar
no, it doesn't
HP isn't cheap, and trying to find a cheap solution to gain it will just cost you more in the end
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
