Crankshaft position sensor
Old Feb 7, 2011 | 02:39 PM
Holycrap's Avatar
Default Crankshaft position sensor
So after installing the 181 pulley it seems as though i have damaged the sensor( i installed it via the pinning the flywheel method) and it will need to be replaced. My question is, where is this sensor exactly? And how hard is the install. Any how to's?
Old Feb 7, 2011 | 03:22 PM
Default Re: Crankshaft position sensor
Its on the passenger side, rear of the head, down by the bellhousing.
Old Feb 7, 2011 | 03:31 PM
Holycrap's Avatar
Hmmm thats what i thought. Jerry from eurocharged said theres a sensor on the flywheel housing under the car and he called it the " crankshaft position sensor". He must be talking about another one. So whats the sensor thats on the flywheel housing called???
Old Feb 7, 2011 | 03:48 PM
robby363's Avatar
There is a camshaft sensor on the right front cylinder head.
Old Feb 7, 2011 | 05:27 PM
Driver side .......
Old Feb 7, 2011 | 10:10 PM
Some helpful links ..........
https://www.crossfireforum.org/forum/143294-post3.html
https://www.crossfireforum.org/forum/409888-post4.html
https://www.crossfireforum.org/forum/397864-post1.html
PeachPartsWiki: R&R of the Crankshaft Position Sensor
Your Parts Search Returned 1 Part(s)
Old Feb 8, 2011 | 10:51 AM
freakingfastsrt6's Avatar
Its on the drivers side....Very easy to locate do a search on the sensor location...make sure you have torx sockets I forget what size it was!!!
Old Feb 8, 2011 | 02:14 PM
Holycrap's Avatar
Im sorry to have confused u guys but this is not what im looking for( i had a feeling this might happen but i posted just in case) im lookinh for a sensor thats on the fylwheel housing underneath the car. Supposedly i might have damaged it when i tried to pin the flywheel when i removed the crank pulley.
Old Feb 8, 2011 | 02:23 PM
kingkub57's Avatar
Have you looked in the parts manual to see if it shows what your looking for, try doing a search and there is a sticky section to download the manual as well.
Old Feb 8, 2011 | 05:49 PM
Holycrap's Avatar
Ok i got the code its p0335. I found the sensor. At first i was looking underneath the car since i never messed with anything in tye engine bay.How did i damage this sensor by pinning the flywheel?????? Im so freaking confused right now.
Old Feb 8, 2011 | 08:51 PM
My guess is that you did not damage the CPS, but you could have damaged something else taking the bolt out with a long wrench, look in the area at the front of the engine.
Old Feb 8, 2011 | 09:56 PM
MikeR's Avatar
P0335 is the crankshaft position sensor error.... you may have just gotten lucky and it failed when you did the upgrade...
fortunately it is a fairly cheap and easy fix.... about $50-$70 and 10-15 minutes...
Old Feb 9, 2011 | 08:49 PM
Holycrap's Avatar
everything in front of the engine is fine. I did notice however that the 181 pulley is pretty big and only comes about 1/4 inch or less from touching the waterpump pulley. i can only imagine how huge the 185 is. Jerry said its common that the cps gets damaged when using the flywheel method. i have emailed him so he can tell me exactly how that happens.Sensor has just been ordered. i'll keep everyone posted.
Old Feb 9, 2011 | 09:04 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
When you say "pin the flywheel" what exactly did you do to pin it?
Old Feb 9, 2011 | 09:11 PM
Holycrap's Avatar
Pinned it with a flathead screwdriver as the Let instructions stated.
Old Feb 9, 2011 | 09:20 PM
Sparky asked the same question that I was going to ask when I saw your post. The flywheel rotates close to the CPS and I have to ask if you managed to damaged the flywheel by raising the surface that passes under the sensor.
There is an actual tool that fits in both the holes that locks the flywheel, using a small screwdriver would make it rise to the top of the teeth and possibly make a burr and that would shave the sensor tip.
Do not fit the new sensor until you have addressed the burr if that's the case or you will ruin the new sensor.
Old Feb 9, 2011 | 09:28 PM
Holycrap's Avatar
This is the response i got from Jerry.
"The sensor sits about 2mm away from the flywheel. When you pull or
push on the flywheel, you cause it to either move in or out. When
this happens, it will touch the sensor at some point in the rotation."
so yea i must have moved the flywheel somehow. the flywheel looks,rotates and sounds fine from underneath the car. I looked at it again. i doubt i damaged anything from just pinning it but it is a possibilty and it can be very costly. i need to get underneath and really look at it while someone tries to crank it again. Jerry said to check for wobbles. i'll make sure it rotates true before i install the sensor and wreck that one as well.
Old Feb 9, 2011 | 09:43 PM
I think that 2mm (.080") away is way too much, I think that it is more likely in the region of .2mm (.008" if that), if your flywheel moved 2mm up and down you would here a rumbling noise because the engine would be ruined.
As I said earlier a burr would wipe out the sensor.
Edit
If the flywheel moved .2mm the engine (crankshaft) would be toast as well.
Old Feb 9, 2011 | 10:10 PM
Edit
I can't fathom that pinning the flywheel with a scewdriver would make the flywheel flex enough to cause this.
Old Feb 9, 2011 | 11:29 PM
That's my point, the flywheel would move imperceptibly, for it to move the bearings would have to have a lot of play in them. The flywheel can move fore and aft (.003 to .010)more than up and down (.001 to .002).
The flywheel can only move up and down by the amount of clearance in the main bearings.
If you study the repair manual you see that a special tool is used, this locates in the threaded mounting holes of the starter and a section of the tool locates and locks into the flywheel teeth.
When the CPS is removed look for a scrape or gouge on the metal and plastic face, a mark would suggest that the flywheel touched the sensor and damage it.
I do not believe the coincidence that the CPS failed at the same time as your pulley change, the odds are really remote on that happening when you think about it.
6. Using Special Tool 9102 Flywheel Locking Tool (1), lock the flywheel by inserting the tool into the starter opening.
Starter teeth take a lot of abuse and get worn quite severely, a damaged starter gear can do a lot of damage on the flywheel teeth requiring a new flywheel. I am not saying that is the case here, but it can happen. I have seen the damage on a car I owned, fortunately the starter gear failed before the flywheel was completely ruined.
