Running Hotter With Supercooler?
Old Jun 22, 2011 | 07:41 AM
The Bobby's Avatar
Default Running Hotter With Supercooler?
I installed the supercooler in March and at first the engine was a few clicks cooler than normal, but now with Chicago Summer driving the thermostat is a few clicks hotter than normal with the massive supercooler. Any ideas?
Thanks
Supercooler
Iso Kit
Dual Big Filters
Thermal Lower Y Pipe
Old Jun 22, 2011 | 08:42 AM
tighed1's Avatar
Default Re: Running Hotter With Supercooler?
The Supercooler will block some of the airflow to the radiator so as the temps go up so may your cars temp go up.
Did you separate the cooling systems?
It's been 100+ around here and my cars run a bit hotter than "normal" (both have Supercoolers)
Old Jun 22, 2011 | 08:49 AM
ImportLabSRT's Avatar
I ran a pair of 8" pusher fans behind the grill on my supercooler to help with air flow to both the supercooler and radiator.
Old Jun 22, 2011 | 08:54 AM
tunaglove's Avatar
Did you have those on a thermistat or switch?
Old Jun 22, 2011 | 08:57 AM
I wired them to charged air water pump which was hard wired when the ignition was on. It helped a lot, plus I could keep the fans/pump on with the engine off to cool the fluid in the charged air circuit.
Old Jul 5, 2011 | 09:16 PM
tom2112's Avatar
She can ride with me ;)
Do you have the separation valve open or closed?
I've noticed that when I'm not racing, if I open the valve the engine temps run cooler (it's like having two radiators). But for racing, I close the valve because I was cooler intake temps.
Nov 11, 2015 05:22 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
cjw
Oct 26, 2015 10:26 PM
Oct 1, 2015 01:42 AM
cjw
Sep 27, 2015 10:22 AM
