NeedsWings Tweaked Manifolds: Dyno Tune Results
Old Jun 25, 2015 | 03:35 AM
  #41 (permalink)
Sweet2002's Avatar
Default Re: NeedsWings Tweaked Manifolds: Dyno Tune Results
I've been looking for a 70mm SC pulley or getting my stock 74 mm turned so I can add the wideband, Oil separator, and the 178mm/PSK parts I have gathered. I should be getting a used SL55 fuel pump I found on ebay from a 49k mile car. I will add Rob's filter and regulator to complete the fuel mods, maybe even go with a 69mm SC pulley. Now I am convinced that the tweaked intakes are worth the cost as far as the HP/TQ gained. My one question is I have not seen the lower Ported "Y" listed in any of the cars that the owners responded to these Tweaked threads. Just not mentioned? I would think it would compliment the intakes very well and maybe give the 15/15 HP/TQ I mentioned in my last post. This is at the wheels so much the better. Pulleys first and then the "tweaked intakes and lower "Y"! I would have likes to run in the 11.9x range but will be happy with a sub 12.25 et.
With the parts listed here and the DCAI from Rob, which I am going to insulate, and a remote DYNO tune from Jerry should sub 12.25 be likely?
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
rogerlemoine
Oct 26, 2015 12:02 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
