62mm SRT6 Pulley Available Now
Old Oct 28, 2013 | 09:37 AM
  #301 (permalink)
RED DOG's Avatar
Default Re: 62mm SRT6 Pulley Available Now
I was a little late getting to the party on this but I just received the "bling bling" belt wrap pulley system (including all the other "bling bling" pulleys available through LateModel21 . . . Five pulleys in all.) WOW . . . everything is B E A U T I F U L.
Additional info and photos are contained in other posts in this thread . . . Chris was super to work with too! Highly recommended!!
Old Oct 28, 2013 | 10:55 AM
  #302 (permalink)
That is a nice setup.
Old Oct 30, 2013 | 07:18 PM
  #303 (permalink)
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
OMG that looks sweet !! LM21 enlisted you to tease me didn't he
Old Oct 30, 2013 | 07:27 PM
  #304 (permalink)
itsky's Avatar
Looking good!
Old Oct 30, 2013 | 08:48 PM
  #305 (permalink)
Bigkid's Avatar
Very nice Red Dog. How does she pull now?
Old Oct 31, 2013 | 06:44 PM
  #306 (permalink)
RED DOG's Avatar
Default
Actually that photo is of Latemodel21's Mercedes engine. I haven't installed my bling bling pulleys yet. Still waiting for my 62mm Karmen supercharger pulley to arrive at my door. I'll post a photo of my engine bay when everything is installed. I also have some more goodies on the way from Rob at Needswings! Anxious to get the tools out again . . .
Old Oct 31, 2013 | 09:07 PM
  #307 (permalink)
And you have the climate to do it in.....cold and raining here.....that will be a very nice looking and running set up
Old Feb 15, 2014 | 08:44 PM
  #308 (permalink)
JesseJamessrt6's Avatar
I need a new bearing. What is the current go to bearing? Does Rudy sell them or has anyone used and verified one in 180's links?
A previous thread said the outside diameter (D) was 47mm. The internal diameter is the same as the OEM one and therefore (d) is 32mm. By my estimate the spacer washer shipped with this pulley is 5mm thick.
So we have 32mm x 47mm x 18mm. that would be Nachi #
32BG04S3G-2DL available at bearingsdirect.com for $23.59.
or
NSK#32BD4718DUK available at Bearing Source
for $21.70
OEM SC pulley bearing.
32
mm x 55mm x 23mm.
NSK #32BD45DU or 32BD45DUM, available at BearingSource for $15.40
or
Nachi #32BG05S1- 2DST
Available at bearingsdirect.com for $20.49 and Amazon at $28.53
These are double row, angular contact ball bearings grease filled for auto air conditioners.
Idler and tension pulley bearings.
Good for 15,000 rpm.
#6303DU or #6303DDU
Available at bearing-source.com
Or
For #63032RS or 6303ZZ try bearingsdirect.com
Better bearings are from the SKF range. SKF 6303-2RSL and SKF 6303-2Z, good for 17,000rpm, these bearings are sealed on both sides.
The highest RPM rated bearings (22,000rpm) are sealed on one side, SKF 6303-Z or SKF 6303-RSL if you can find them. If a bearing is sealed on one side only it is easy to clean it and repack with a suitable grease at regular intervals to get extra life out of it, the grease gets thrown out during operation. Put the seal towards the front of the car and hope that not too much crap gets around the back. Using double sealed bearings is best.
These bearings are limited by the speed that the seal can withstand. An unsealed bearing (6303) can do 22,000rpm and the fastest sealed bearing have non contact seals.
These are all single row, deep groove ball bearings, grease filled.
Old Feb 15, 2014 | 08:48 PM
  #309 (permalink)
rcompart's Avatar
I have a few left overs. Cover shipping and I'll throw one in the mail Monday.
Old Feb 15, 2014 | 08:52 PM
  #310 (permalink)
Wow, thank you! I appreciate you doing that. PM sent.
Old Feb 15, 2014 | 10:58 PM
  #311 (permalink)
Billy22Bob's Avatar
deleted...in er
Old Feb 15, 2014 | 11:23 PM
  #312 (permalink)
rcompart's Avatar
Originally Posted by Billy22Bob
deleted...in er
I apologize for my harsh and overstated comment.
Old Feb 15, 2014 | 11:37 PM
  #313 (permalink)
Lenin's Avatar
chuckle chuckle
Old Feb 16, 2014 | 01:56 AM
  #314 (permalink)
TommyT's Avatar
That was outstanding.
Old Feb 16, 2014 | 05:13 AM
  #315 (permalink)
RED DOG's Avatar
o u c h ! ! !
Old Aug 2, 2014 | 10:40 AM
  #316 (permalink)
RED DOG's Avatar
Not posting this to be critical of the Karmen 62mm supercharger pulley but thought those who have one might want to check it. Mine grenaded on me yesterday and the chunk of metal flew up and damaged my hood. I had less than 300 miles on the pulley . . .
Old Aug 2, 2014 | 11:52 AM
  #317 (permalink)
Lenin's Avatar
I have it's twin. Happened to me 6 months ago. Since I got mine directly from the manufacturing guy, he quickly sent me a replacement without any issues. I only put it back on 3 days ago and therefore don't have any valid feedback yet. It is hard to check for this kind of failure. This is not a rivets or a spring issue. Other than a manufacturing defect, my only suspicion is improper gap of the SC pulley itself. The gap should be 0.25mm-0.3mm. And even then, it should not fail like this.
Old Aug 2, 2014 | 12:16 PM
  #318 (permalink)
JimmieC's Avatar
I lost a 65mm pulley. one of the flat springs broke and came out and sliced thru the s shaped water hose that goes to the oil cooler. lost the water.
Old Aug 2, 2014 | 12:58 PM
  #319 (permalink)
Coyote's Avatar
I got one of these from the original group buy, and I've probably got about 30,000 miles on it now. So far, no such problem. However, as I'm in the process of changing the valve cover (and breather cover) gaskets, I'm going to take a look at that today. Thanks for the head's up.
Old Aug 2, 2014 | 01:41 PM
  #320 (permalink)
dinasrt's Avatar
You may need a microscope? I'm sure others have thrashed their new karmann pulleys just as hard as the ones that failed(like Rudy for example), and no issue so far. Hopefully someone can nail down the root cause.
