HELP!!! - Leaking gas sitting in the carport
Old Dec 19, 2012 | 02:31 PM
chuK_138's Avatar
Default HELP!!! - Leaking gas sitting in the carport
So this is scary as hell....our 6 is leaking gas from somewhere around the tank. I haven't taken it anywhere but the track in the past month, last outing on 12/7, and we've noticed a gas smell in our carport for about a week. Started both the XFs today to check fluids and such when I noticed this giant stain under where the SRT normally sits. Smells like water and gas, feels slick like coolant. After moving the car forward to inspect, I noticed something dripping out of the drip pan in front of the rear wheels beneath the tank. Mystery fluid does not smell entirely like gas, but she lost an 1/8th of a tank without being moved last week. Please, any insight would be most helpful! Heck, I almost sprung a leak when I saw this.
Old Dec 19, 2012 | 02:35 PM
Default Re: HELP!!!!!-Leaking gas sitting in the carport
Remove the plastic cover ( tray ), loooong extension 10mm socket for the plastic nuts and inspect all the connections to the pump and the filter.
Most likely dry-rot hose at a connection.
( you can usually release those OEM hose clamps with a tiny screw driver at each side of the clamp where it hooks )
Old Dec 19, 2012 | 02:44 PM
I was thinking the same thing, probably a fitting or hose to the fuel filter.
I ended up putting AC style clamps on mine, they hold up better...
Old Dec 19, 2012 | 02:49 PM
chuK_138's Avatar
Yeah, it seems it is time for those hoses to be changed. That might also explain why she sounded starved for gas when I cranked it up today.
Old Dec 19, 2012 | 02:51 PM
chuK_138's Avatar
BTW, you guys kick @$$ for responding so fast.
Old Dec 19, 2012 | 02:55 PM
I happen to have a job where I sit at home monitoring ( and sometimes fixing ) database systems all day, when I'm not on conference calls.
This leaves a LOT of spare time to also monitor this forum.
I am also only 15 feet from the garage, if I need to go look at something on the car, it is not too much trouble.
Old Dec 19, 2012 | 04:32 PM
vinnys's Avatar
Mine did the same. It was the pump.
Old Dec 20, 2012 | 08:25 AM
Default Re: HELP!!! - Leaking gas sitting in the carport
I am in IT as well, so I am generally behind some sort of online capable device.
I would recommend changing the fuel filter at the same time, Rob has them available...
Valk
Jul 12, 2021 09:49 PM
franklindm
Mar 14, 2020 12:23 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Charlesl
Sep 30, 2015 10:46 PM
RacerXofFL
Sep 15, 2015 05:00 PM
