Intake air temps high.
Old Oct 22, 2013 | 12:30 AM
JEFASOLD's Avatar
Default Intake air temps high.
On my way home this afternoon, I got a high intake air temp alarm on my ultragauge. I turned the gauge to page 5 to monitor the temps and watched as they varied from 187 dropping down to 160+ then slowly rise to over 200 with no change in speed, a steady 55. I have the NW DCAI and modified manifolds woth no other changes to the intake system, could this be a problem with the supercharger intercooler or?????? Any suggestions will be appreciated.
Old Oct 22, 2013 | 01:29 AM
hustler316's Avatar
Default Re: Intake air temps high.
I would first verify your gauge is working properly. Then look at your intercooler pump. Sounds like your pump may be going out.
Old Oct 22, 2013 | 07:02 AM
grip grip's Avatar
+1 on intercooler pump. $100 pump and easy DIY install.
Old Oct 22, 2013 | 07:41 AM
velociabstract's Avatar
+ on the intercooler pump dead or near death.
Les
Old Oct 22, 2013 | 12:10 PM
NeedsWings's Avatar
IC fluid is not circulating
Old Oct 22, 2013 | 12:17 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Yes. My Ultragauge showed these temps when my IC pump was on its was out.
Old Oct 22, 2013 | 01:50 PM
I have to agree....unless there is an obstruction, and not likely, it is the pump. Nice to have the guage to know rather than a bucking car....
Old Oct 22, 2013 | 03:16 PM
RL67037's Avatar
So, with a stock intake, what should the IAT range of temps be if everything is working properly. I figure that the outside air temps will affect the IAT, so is there a number above the OAT that one would look for when using a stock intake?
Old Oct 22, 2013 | 03:30 PM
20 to 30º over ambient temperature. Mine run at 30º.
Les
Old Oct 22, 2013 | 04:32 PM
RL67037's Avatar
Les
Thanks Les - I'll check them out.
RL
Old Oct 22, 2013 | 07:56 PM
JEFASOLD's Avatar
Thanks for the replies and I guess my pump is going, which is a surprise since this is the Johnson pump that I just installed last Sept. I will check the fuse and connections first, then a new pump. Anyone have a recommendation on the best replacement?
Old Oct 22, 2013 | 08:50 PM
RL67037's Avatar
I used the updated Bosch because it was a plug and play and I didn't want toodify the bracket and the connector. It's been in about 15 months with no issues that I know of. That said - I don't use this car as my daily driver so I've only put about 5K miles on the pump (I think).
Old Oct 22, 2013 | 09:25 PM
I've heard complaints about the Johnson burning out early on the MB place. I have the Bosch 010 and it seems to move the water pretty good.
Les
Old Oct 22, 2013 | 11:25 PM
JEFASOLD's Avatar
Originally Posted by RL67037
I used the updated Bosch because it was a plug and play and I didn't want toodify the bracket and the connector. It's been in about 15 months with no issues that I know of. That said - I don't use this far as my daily driver so I've only put about 5K miles on the pump (I think).
I only have less than 4k on mine since last year, not my daily driver either.
Les
I did notice the mention of this pump failing early on the MB forum and if I remember correctly, on our forum, there was a thread that proposed the theory that in operation, the Johnson didn't flow as much as was expected. Saying that, the Bosch would appear to be a good option. Thanks for the input, much appreciated.
Old Oct 23, 2013 | 12:15 AM
Florida where the roads are 125* in the middle of the day and about 90 at night but My Iat's are in the 40 to 50's jim
Old Oct 23, 2013 | 10:39 PM
JEFASOLD's Avatar
Thanks, yeah I would expect them to be a bit below ambient at worst. Checked my fuse, OK, so tomorrow, I remove the wheel well liner and check my connections but it's looking like the pump. If this is as bad as it gets, I can live with it, I have had no other issues with the car so far.
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
