SRT6 Fuel Pressure setting with AEM Pressure Regulator???
Old 05-08-2014, 07:46 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: SRT6 Fuel Pressure setting with AEM Pressure Regulator???
Originally Posted by oledoc2u
Was Rob's recommendation for the 65mm pulley? Makes sense. You are running the 62mm. So I would think a bump would be required. Just guessing. I may have to go to this as I don't want to change injectors. And Yes. Modding is so wonderful......lol
Doc, Rob also told me to start at 58 and move it up as required.
Old 05-08-2014, 07:51 PM
OK....well, it seems to have fixed your problem and I am borderline....
Old 05-08-2014, 07:55 PM
Took a couple trips to the dyno but its great to have the AFR's where they should be.
Old 05-08-2014, 08:12 PM
Wish I had a good dyno near me. I have meth kit I won't install, and A/F's borderline....and not much we can do right now. Need to get up to Chicago and get some things done real soon. 1/2 mile event will be here before I know it....thanks for the update...
Old 05-08-2014, 08:15 PM
bluecoupe's Avatar
Don't make me post that picture I have of you in bed with that goat!!!!. I'd probably have to ask you for help instructions to post it though.
Oh, I guess everyone knows now....ooops.
I'd love to see a picture of a goat with an old goat!
Old 05-08-2014, 08:27 PM
LMAO......I was thinking that too.
Old 05-08-2014, 08:29 PM
With the NW DCAI you will be getting more air than me. That will get you leaner too....maybe?
Old 05-08-2014, 08:31 PM
yeah, it is only there at the end of the quarter....so I have to be careful for long sustained highway runs....
Old 05-08-2014, 11:43 PM
JEFASOLD's Avatar
I've been told the stock regulated filter limits pressure at 54 psi.........but I didnt have a built-in pressure gauge installed with the stock filter to verify that.
Before I installed my fuel regulator, I installed the extra gauge in the engine bay and with the stock filter-regulator but with the SL55 pump, I was reading 58. I need to get a hose to connect the vacuum line and then I will be finished with the install. For some reason my regulator came without any hoses or clamps whatsoever. Fortunately, I had some fuel line from an old regulator that I had lying around, so a trip to NAPA and all should be well. Good to hear that we may not need injectors, that will make my day.
Old 05-09-2014, 04:24 PM
boostmonkey's Avatar
I am at 65 psi fixed. I am not sure that is relevant to you... But anyway, there it is.
https://www.crossfireforum.org/forum...fuel-rail.html
Old 05-09-2014, 04:59 PM
meh03's Avatar
I'm running a 65mm pulley, single CAI, and about to install NW Manis and a SL55 pump. Low Texas elevation. I was going to replace the stock filter with a new one while installing the pump. Now I'm wondering if I might need to go with the un-regulated filter and separate regulator. Not stacked, but I'm thinking I may be borderline.
Old 05-09-2014, 05:56 PM
For the 65, history would say you are fine but if you ever go smaller or stacked you'll need more fuel. Its a whole lot easier to do it all at once than going back and doing it again. Then you can dial in the pressure as well.
Old 05-10-2014, 12:21 AM
Can someone send me the instructions for the nw fuel mod? The srt 6 I bought has it installed and I'm about to put on new manis and go from scai to dcai so I want to know as much as I can about the system.
Old 05-10-2014, 04:58 AM
RED DOG's Avatar
These are the instructions I got from Rob at Needswings:
1. jack up back of car, or just reverse it up onto ramps
2. remove black plastic shield covering fuel pump/filter
3. remove oem filter/regulator, wear glasses as fuel will spray when you remove the first line
4. swap in new filter, line from pump goes to the filter in,
5. line from out on filter goes to the regulator in either 3 or 9 oclock position, flow can go either way
6. line that went to tank on oem filter goes to the bottom port on regulator
7. install gauge onto face of regulator, use Teflon tape or paste, I prefer paste
8. small vac line from oem filter goes to small port on top of new regulator
9. mount new regulator to underbody bolt with supplied aem bracket
10. zip tie up the excess lines to secure them
11. have buddy turn key to on position without starting car, while your underneath watch the pressure gauge and get the regulator to 58psi
12. start car and verify pressure setting while running, the car will chug a few times on initial start up while it purges out the air bubbles
13. check for leak, recheck for leaks, after test driving check for leaks again, once all leaks are tightened up put the plastic shield back under the car and enjoy.
Old 05-10-2014, 07:14 AM
TommyT's Avatar
I have those mods(minus the pump) in Austin and have no problems.
Old 05-10-2014, 08:24 AM
Beaner's Avatar
ps. My car is a beast....no doubt a E55 Crossfire killer.
Here we go... princess gets some upgrades and thinks he is "The Man"
Did the VTech just kick in yo???
Old 05-10-2014, 08:28 AM
LOL....took you long enough.
  #38 (permalink)
Old 05-10-2014, 08:22 PM
JEFASOLD's Avatar
It should look something like this.
  #39 (permalink)
Old 05-11-2014, 07:35 AM
bluecoupe's Avatar
Let's hope he can beat my NA @ the 1/8th mile now
  #40 (permalink)
Old 05-11-2014, 06:27 PM
meh03's Avatar
Nice. Thank you for that reply!
Quick Reply: SRT6 Fuel Pressure setting with AEM Pressure Regulator???
