Supercharger Coolant Pump and Coolant
Old Dec 15, 2014 | 06:54 PM
brnhn3's Avatar
Default Supercharger Coolant Pump and Coolant
I am in the middle of changing out my coolant pump for the supercharger but here are some issues... First. The pump that is installed is not OEM and not an OEM replacement part... I ordered the Bosch replacement pump a few weeks ago, I managed to get the connector as you'll be able to see it wasn't there on the current pump. Secondly, I have to make a new bracket out of steel wire to fit the current holes to hold the bigger pump in place... Finally, once I remove the current pump and the fluid drains... Do I fill it from the coolant cap on the radiator? I heard that it's a separate system that's why I'm asking, if anyone has info that'd be helpful!
-Bryan H
Old Dec 15, 2014 | 07:03 PM
32krazy!'s Avatar
Default Re: Supercharger Coolant Pump and Coolant
if the system is poem then its not separated. many do separate the system for added cooling and if it is then there should be a filler point either on the heat exchanger or a tank. if not then fill from the radiator.
Old Dec 15, 2014 | 09:48 PM
If you pinch off the hoses, you will only loose a couple ounces. Please tell me you didn't take the headlight assy out for this job.
Old Dec 16, 2014 | 10:34 PM
ChrisA's Avatar
This is one upgrade im following so all info is important. Thanks for the pictures.
Old Dec 18, 2014 | 01:11 PM
boostmonkey's Avatar
Is that a Johnson CM30 pump? It looks like it might be. If so, that's an UPGRADE from the OEM pump. You don't want to switch back!
Old Dec 18, 2014 | 07:01 PM
JEFASOLD's Avatar
I'm not convinced that the Johnson is an upgrade. I bought one from EC and it lasted all of 2k miles, money thrown away. I went to the Bosch replacement and all has been fine for 2 years.
Old Dec 18, 2014 | 07:17 PM
The thinking these days is to go with the Bosch 0 392 022 010 which is a direct replacement of the 002 pump and the impeller does not fly to pieces.
From what I can see of the pictures the original clamp is being used and does fit the new pump and did fit the Johnson as well if I remember correctly. If so why the new fangled strap?
Old Dec 18, 2014 | 07:28 PM
JEFASOLD's Avatar
The pump I went to was the 010 Bosch. The Johnson pump is smaller in diameter and did not have a rubber sleeve but I was wondering about that rigged strap myself.
Old Dec 18, 2014 | 07:36 PM
velociabstract's Avatar
Classic back yard engineering. If it works and is out of sight ……..
Les
Old Dec 18, 2014 | 08:21 PM
I see looking back that my memory is not too good, especially as I have had both pumps in my hand.
I had a spare Johnson, sounds like every man should, but I replaced the OEM pump with the Bosch 010 before the OEM one flew apart.
The trouble with using that strapping is that it is hard to clamp down if the holes do not align just right.
Old Jan 29, 2015 | 11:32 PM
brnhn3's Avatar
Sorry I've been away, yes I had heard taking out the headlight was necessary. Although it was a PAIN to get out, it did make the whole process much easier! The new pump has never faltered even at full throttle for extended periods, as far as fitting the bracket to hold it in place the 'Holy Metal' jig works very well and I ended up putting a small bolt through two of the holes once the pump was in place and secured it with a nut, it took all the slack out of the metal banding and there is no wiggle room. It worked better than expected actually!
For anyone looking to do this, even though it's a pain, the pump is much easier to work with when the headlight is removed.
Tape EVERYTHING when removing headlight assembly, the adjustment nuts on the bottom of the housing would wreck havoc on the paint!!!
If you're looking for a wiring harness (Yellow and leads seen in last picture) go DIRECTLY to Mercedes, I had talked to 4 Chrysler shops and nobody could help at all...
Provided you had all the required tools and supplies ahead of time (Unlike me) this can easily be completed in 2 hours max
Old Jan 29, 2015 | 11:39 PM
I took of the wheel and the front fender liner which gave lots of room to play around in.
Old Jan 30, 2015 | 11:45 AM
tighed1's Avatar
A little extra that may help.
Really easy to get to with the front bumper cover removed! More pictures of the pump area and how to separate the systems in this thread.
https://www.crossfireforum.org/forum...r-install.html
Old Jan 30, 2015 | 12:17 PM
I would sooner take the wheel and fender liner off than the bumper cover. They are not so big and don't scratch to easy.
Lots of room.
Old Apr 4, 2015 | 04:21 PM
Timesnow's Avatar
Where did you get this supper cooler?
Old Apr 5, 2015 | 10:36 AM
tighed1's Avatar
Made mine.
Believe Needswings sells (or used to) a similar set up.
Old Apr 5, 2015 | 12:41 PM
Put it up in the air on a lift and replaced mine. Still using the 010...
Old Apr 5, 2015 | 09:28 PM
JEFASOLD's Avatar
I like the heat exchanger that I purchased from EC, although the mounting system didn;t knock my socks off, so I devised a better method. It is shorter thicker and wider than stock, doesn't cover as much of the main radiator as stock and with a couple mods to get more airflow has kept my temps in control.
minimayhem
16
Aug 23, 2016 07:47 AM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
