Anyone using these needswings mods
Old Jan 16, 2015 | 06:43 PM
chuK_138's Avatar
Default Re: Anyone using these needswings mods
Stacking will definitely require more fuel.
Old Jan 16, 2015 | 06:46 PM
rmcdaniel12's Avatar
Literally my initial point chuk haha. No worries man. Sorry if i wasnt clear about my mods on deck.
Old Jan 16, 2015 | 11:01 PM
JEFASOLD's Avatar
To clear things up a bit. If you aren't running lean, there can be an advantage to the bigger injectors in that the duty cycle will be lower and thus may add some reliability in that area, without actually increasing performance. Your choice of the 178 pulley is good, with the 181 crank pulley and that SC pulley you will be exceeding the safe limits of RPM on the SC pulley bearing.
Old Jan 16, 2015 | 11:05 PM
Thanks for the heads up on that. U just made my decision very easy.
Old Jan 16, 2015 | 11:14 PM
JEFASOLD's Avatar
You're welcome. If you can find it 32 CRAZY posted a chart with much good info on the percent of overdrive of residuals and rpm of SC pulley with the various combinations, gains, etc. It's worth a read, he even listed the members who had each of these setups. Good luck.
Old Jan 16, 2015 | 11:16 PM
Interesting. Id like to read that.
Old Jan 18, 2015 | 07:08 PM
BrianBrave did this chart.
Old Jan 18, 2015 | 09:33 PM
JEFASOLD's Avatar
I may have given false info on that chart, it might have been BOOSTMONKEY, I took a cursory look but didn.t find it immediately but a more thorough search will turn it up.
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
rogerlemoine
Oct 26, 2015 12:02 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
