Well I almost bought one of the NEEDSWINGS intakes...
I guess the deal fell through. Again, who has these intakes and would you recommend my getting them and the ported "Y" or look for power some other way? $750. with the "Y" is a lot of cash for 20whp, if that.
Other than an idea I have for the exhaust system, which will likely not yield much I see nothing more to do to ma street car. I could just concentrate on my tires. I am a bit concerned if I stop the spin with sticky tires will the motor bog? Any ideas are welcome. Are their any stations in florida that sell 100 octane fuel. I did a google search that must be old because none so far have heard of such an octane!
Dont bother with 100 octane fuel, it will not yield you any more HP if your car is not tuned to run it. The stock tune is design to run with 91/93 as that is readily available through the USA.
You best bet is to focus on a good set of tires that accomplish what your trying to do with the car, rather that is drag racing or track racing there is a tire for you.
the needswings intake and Y pipe do more than just give you hp, when you drive after installing them you will say Oh S*** I like this ,, also when you open the hood ,if anyone is around to see your face they will see one hela of a grin and then they will look at your eng bay and know why you have a s*** eating grin on your face get and reap the benefits jim
Ethanol-free gas stations in the U.S. and Canada
And check here for pricing on 100LL AvGas...
AirNav: Great Deals on 100LL Avgas
http://www.airnav.com/fuel/local.html
there is a bunch in Miami and maybe a half dozen in Ft Laud.. and 4 or 5 in Palm Beach. all on the way to the track any thing above 100 oct you will have to put the gas in a container between Oakland and Commercial there is a station that has high performance gas from 100 unleaded to 110 leaded. jim
If you are talking about the tweaked manifolds (SRT6 / SLK32 / C32 Tweaked Stock Intake Manifolds) I have them and the ported y.
I would say the manifolds should be one of the first things done to get rid of the restriction they have in stock form.
If you're up for it (and can find a suitable Y pipe) I'd go for Sify's intake design here....~$300 for local USA.
But the Y-Pipe is the sticker.
The language has me confused on these forums for the 3.2 motors. When the ported "Y" is mentioned in the same sentence we should be talking about modified stock intake manifolds, a cast piece. Between the 2 the cast is what...$750.? $599. for the intakes( along with a $500. core charge while a set are being prepped for another customer, and many see intake and see and it seems only see the dual cold air
INTAKES! Then NW has a set of sheetmetal intakes that are supposed to add 40+WHP across a wide rpm range that number I have yet to confirm, or it's duration. These sell for $1499. on sale with new bolts and gaskets. If anyone has tried both or has hard numbers on either please let your numbers speak! Mark
Instead of high octane, find a station nearby with non-ethanol gas. Here's the latest list for FL.....
AirNav: Local Fuel Prices
[QUOTE=Sweet2002;825996]I guess the deal fell through. Again, who has these intakes and would you recommend my getting them and the ported "Y" or look for power some other way? $750. with the "Y" is a lot of cash for 20whp, if that.
this a step at a time. Doc is right, more air is always the key to more power, in and out. We can't do much about the air out but that isn't as important with the SC as it would be with a N/A car. Search thoroughly the engine mods, figure out what you want to do, then do 1 and see what change it makes, then another, etc. If you do them all at once you won't know what did what.
Jerry(Eurocharged) said I could expect a 30HP increase with the race TORCO tune. I already have the TORCO and might as well get a tune and enjoy what it gives. The problem as i see it is the lack of a DYNO tune for these motors. Email has to be more conservative. I logged 19psi(I guess that high a boost figure has to do with the restrictive intakes and 19.5* of timing. Anyone have a log to compare what you high numbers for boost and timing? THX, Mark
After installing the K&N air filters 33-2256 - K&N Replacement Filters, Replacement Air Filter in the OEM intake, I noticed a significant improvement. They're some $45 a piece.
I guess you just got them then huh?
I just ordered mine last week with a catch can. Car already has K&N panel filters right now. But I never believed a K&N filter did anything better then a paper filter except for lasting a long time.
Anyone have a link to these intake mods?
