Help please
Old Dec 30, 2015 | 10:16 PM
JimmyJames's Avatar
Default Help please
I have a noise under the hood and thought the belt tensioner when I just check I found a plastic rim coming out of the crank pulley. It's about 25 to 30% out on one side but still flush around the rest of the pulley.
I tried the search and found nothing---any help?
Grip Grip---If you have and idea it would be great. I am the guy near you that bought the K& N's from you a few years ago.
Thanks all
Jimmy
Old Dec 30, 2015 | 10:50 PM
Default Re: Help please
if it looks like this ,it is getting ready to come apart replace it before you drive again. pic is not of pulley from crossfire.
Old Dec 30, 2015 | 11:57 PM
4drturbo's Avatar
Curious, mileage on car? As what AMX said, replace it ASAP
Old Dec 31, 2015 | 12:06 AM
Mrmiata's Avatar
Thanks all
Jimmy
I have no clue where the thread is that I've read this before.. but yeah as noted.. replace that before it grenades on you..
This is the one I was thinking of.. It's a 6 but I'll bet the design is the same..
https://www.crossfireforum.org/forum...-fell-off.html
Old Dec 31, 2015 | 05:49 AM
JimmyJames's Avatar
Thanks to all of you---It's been a while since I have been on but I knew help was here.
I knew it wasn't good but wanted to hear the backup.
Looking for the part now.
Leads here would help too.
Miles on the SRT---27,400.
Also---Steve aka Crazy32
I read the link above and I am in Nashville---If you still have that toll it would be great---It looks like I will be doing this. Thanks Jimmy.
Old Dec 31, 2015 | 08:27 AM
Thanks all
Jimmy
Here's one falling apart, this situation is really dangerous if this flew apart serious damage would occur under the hood. You can see that the rubber is half gone on this one and the outer rim is now off center to the inner.
The part should have the Mercedes part number visible buy the part using that number, not the Chrysler part number.
Old Dec 31, 2015 | 11:15 AM
JimmyJames's Avatar
Yep---That's it Onehundred80
I looked at your thread---which is great---but did not see the procedure for R&R.
I may have missed it---If it is there for the crank pulley could you please tell me which one---THANKS.
It sucks at 27k but so is life at times. My rubber is nice and clean but it's out a good 1/2 inch at the max and then tappers back in. Like I said, 25% or so out around the pulley and then the rest is flush.
It is parked until repair---looking at sites now for the part and the tool too.
Steve is near by but I do not know him---We talked a couple of times a few years ago but that's it.
He offered me to come "wrench" when I bought my car but it only had 917 miles at the time.
Thanks again----I knew help was here.
Old Dec 31, 2015 | 11:22 AM
Here's the tool :
Mercedes Benz M112 M113 Crankshaft Harmonic Balancer Pulley Holder | eBay
Old Dec 31, 2015 | 12:13 PM
pioneer4x4's Avatar
I know I will get chastised for this, but if the rubber is not cracked, I would try tapping it back in. THen run it and see if it runs true. If it seems OK, then keep an eye on it. Worse case you get more time to get a replacement part.
Old Dec 31, 2015 | 04:33 PM
Worse case is that it comes flying apart and causes serious damage under the hood.
Have you ever tried something like this?
This would be like trying to get the genie back into the bottle. The pulley has failed and should be replaced immediately before running the car.
Now think about that and stand in the corner. LOL
How to make your own tool to loosen the crankshaft bolt. Notice there are two types of pulley, the SRT one has more ribs (8) than the NA one which has six.
Definitely buy a new bolt.
Another type of crankshaft locking tool.
Old Jan 1, 2016 | 07:12 AM
pioneer4x4's Avatar
Like I said. I expected this. But it is not a grenade with the pin pulled. I'm sure it has been getting gradually worse over THOUSANDS of miles. Look at the pictures of failed ones, way beyond just rubber coming out, they are cracked/separated/missing rubber. Without seeing it, the issue might not be impending doom.
Old Jan 10, 2016 | 01:23 AM
chuK_138's Avatar
That rubber isolator ring is almost 2" wide. If it looks like it's coming out you're going to lose a chunk, that's all. I took one of the OEM crank pulleys apart thinking that was just a spline. Knowing what I know now, I say fill it with epoxy.
Old Jan 10, 2016 | 08:37 AM
There is epoxy and there is epoxy. Adding some material that is of a different weight and not being able to fill all the voids will leave the pulley unbalanced.
That rubber is a damper for vibrations and at one time it was a homogenous mass, if some of it has separated common sense would dictate that the remainder is compromised. This is not something to play around with, replacement is the safest option, everyone should check their pulley for signs of failure.
I would still be looking for the cause of vibration, leaping to conclusions as to the cause may leave you with a new crankshaft pulley without curing the vibration.
Old Jan 10, 2016 | 09:20 AM
kingdavid54's Avatar
I completely agree with 180, from a safety standpoint the harmonic balancer must be replaced with a new one.
Old Jan 10, 2016 | 02:27 PM
Mrmiata's Avatar
Hey at 6,000 RPM .. how bad could the damage be.. I vote Epoxy!
Old Jan 10, 2016 | 02:34 PM
You just wanna watch, right Greg ?
Old Jan 10, 2016 | 02:39 PM
Mrmiata's Avatar
I'm thinking about a parts car.. Just lining up customers..
Old Jan 10, 2016 | 03:09 PM
Did you say you need a new crankshaft pulley ???????
How could that have happened ?????
Old Jan 11, 2016 | 10:23 AM
JimmieC's Avatar
I have a 38000 mile good used one I will sell.
Old Jan 17, 2016 | 11:38 AM
Dementors's Avatar
I am trying to add a picture of what it should look like for us to reference. I found this picture...is this how it should look? If so, this might be my vibration sound I am hearing as it appears half of the crank pulley is missing this gasket/rubber fill...maybe out of balance. Nothing is protruding, just all of it does not appear to be there. Will find out for sure when I install my new alternator if the sound goes away.
File Type: png
