What is there to do now?
Old Feb 22, 2016 | 03:36 PM
Sweet2002's Avatar
Default What is there to do now?
I believe my mods are fully listed. I have been toying with some simple cooling mods. Mimi said he had 4 holes drilled in his T-stat, maybe 1/4"? This would keep some coolant flowing even when the car /thermostat was closed keeping the motor cooler. When my temp needle is at 9AM and not higher the car makes more power for sure. I have the heat exchanger separation kit. How about the holes in the T-stat? Anyone have and if so results? Any other suggestions that may seem off the wall but seem to work? Thaznks
Old Feb 23, 2016 | 12:17 AM
4drturbo's Avatar
Default Re: What is there to do now?
water/methanol injection.
Old Feb 23, 2016 | 01:11 AM
Sweet2002's Avatar
Do you have a meth injection kit or are you,
contemplating a kit? I thought about SNOW kit with 2* more timing as I run a stack of 178/70 for 21psi. I did research and found 3 customers w/question's not answered, not even after I pointed them out! Still.....
Old Feb 23, 2016 | 02:44 AM
dinasrt's Avatar
For a little better cooling: 1.) Give the system a good flush and then use a minimum antifreeze ratio for your coolant and use a water wetter(example 15% antifreeze & 85% distilled water). 2.) Remove the rear hood gasket at the cowl, to allow some of the heat to escape. 3.) Move to a cooler climate.
theglot
Sep 22, 2020 04:58 PM
onehundred80
29
May 12, 2016 02:19 PM
Feb 22, 2016 07:50 AM
DrBob
Feb 20, 2016 04:49 PM
Mr5150
Feb 3, 2016 01:39 AM
