Intercooler Separation Tank Question
Old Aug 31, 2018 | 03:42 PM
Ralph289's Avatar
Default Intercooler Separation Tank Question
I did the same BMW IC separation tank others have done and I also have the "always run IC Pump mod" but looking in the BMW tank there is every little coolant coming out of the small fitting near the top of the BMW tank. Should there be a steady flow coming out the small top fitting ? Car runs great so I know I don't have a bad IC pump. Any ideas ??
Old Aug 31, 2018 | 07:14 PM
Ralph289's Avatar
Default Re: Intercooler Separation Tank Question
WOW....No body have any ideas ?
Old Aug 31, 2018 | 08:56 PM
tunaglove's Avatar
What happens if you pinch the tube below it?
Old Aug 31, 2018 | 09:42 PM
Ralph289's Avatar
I read about that tonight, going to try it in the morning. As I am running pump on all the time mod, guess I really shouldn't have to start the engine just turn the key on when I do that.
Thanks for the info.
Old Aug 31, 2018 | 11:17 PM
dinasrt's Avatar
As tunaglove suggested(I think), it may be an air lock. Also, the BMW reservoir cap has a vent hole in it; so the vent hole should be above the high flow level of the IC system line. It's hard to tell from the pictures, but it looks like perhaps it is placed lower than the feed line? No evidence of weepage there?
Old Sep 1, 2018 | 10:44 AM
Ralph289's Avatar
Yep, it was air bound, I clamped the top intercooler hose and started getting a nice steady stream coming out. Got all the air out and unclamped it and still got a good stream of coolant flowing. All looks good !!!
Thank you all for your help !
Old Sep 1, 2018 | 01:55 PM
tunaglove's Avatar
Looking at your photo, I think you should try to get the tank as high as possible. It can go quite a ways before touching the hood.
Old Sep 1, 2018 | 02:27 PM
dinasrt's Avatar
Yes, you shouldn't be able to see the flow cascading out the top nipple. The flow should be under the fill level. You can check flow with your pinkie finger. Even after a good run at the track, my IC water temp. is never too hot to dip the pinkie in. It's nice to be able to monitor the fill with the reservoir. I anticipate that some day perhaps, I'll see it low and may have to buy one of Rudy's custom IC's.
Old Sep 1, 2018 | 05:20 PM
Morphh's Avatar
How did u run the bottom hoses of bmw power steering bottle? Or is it just used to fill
Old Sep 1, 2018 | 06:57 PM
tunaglove's Avatar
Just use one bottom port to a tee. Plug the other.
Old Sep 1, 2018 | 07:04 PM
Morphh's Avatar
So it’s just used to fill the system
Old Sep 1, 2018 | 08:07 PM
dinasrt's Avatar
What else would it be used for? When you completely separate the two systems, you can use different coolant fluid. For example, I use straight distilled water and a bottle of water wetter for the IC system for most all of the year. The reservoir serves to fill the system, flush the system, check the fill level, check to see if it's flowing well or not, drop a temp. gauge into it after a hot lap if you're in to logging that or not, can be fitted and used to pressurize the IC system to find/verify a leak(hopefully a hose end and not your IC!)
Old Sep 1, 2018 | 08:09 PM
Morphh's Avatar
I thought some pple where using it as a tank to increase volume by using the bottom 2 hoses inline with ic coolant lines
Old Sep 1, 2018 | 09:55 PM
Ralph289's Avatar
It adds about 2 cups of fluid capacity, but nice to have a place where you can tell if there are leaks like what was mentioned
Old Sep 1, 2018 | 09:59 PM
Morphh's Avatar
I blocked one of the nipples
I didn’t know u can use it for volume isn’t one nipple bigger then the other?
Old Sep 1, 2018 | 10:03 PM
Ralph289's Avatar
Block the smaller one.
Old Sep 1, 2018 | 10:32 PM
Morphh's Avatar
But u can use it for adding more volume to the system? Running it inline with ic lines? It want slow the flow down cause of the filter in it?
boostmonkey
Mar 24, 2021 10:17 AM
onehundred80
Mar 1, 2014 05:49 PM
smpshady
Jul 23, 2009 01:39 PM
BrianBrave
May 9, 2008 09:56 AM
MUTT
Mar 3, 2008 07:22 AM
