Foam block in left rear fender well from factory?
Old Nov 8, 2025 | 07:15 PM
Gkayaker's Avatar
Default Foam block in left rear fender well from factory?
Apologies if this is old news, but my search finds nothing. SRT6 Roadster. Was exploring the area under the antenna in prep to replace the gasket when I found an irregular block of foam, similar to the recycled foam carpet padding. Approx. 6" x 12" x 4". Not likely it got into that space by accident. Is it factory, does it have a purpose, maybe someone's attempt to silence a rattle? I will try to attach a photo.
not factory, but stylish.
Old Nov 9, 2025 | 02:45 AM
Default Re: Foam block in left rear fender well from factory?
Just a guess; the foam was probably used as sound deadener. Maybe installed at the factory or dealership.
Old Nov 9, 2025 | 11:22 PM
Is this not the area where the pump for opening the doors/gas door is located? When I was under the foam insert in the rear bay, the pump was wrapped in foam that looked like that.
Old Nov 10, 2025 | 02:25 PM
It appears he is showing the area on the left below the antenna
Old Nov 12, 2025 | 07:03 AM
Oooops, ya thats a new one for sure. Hope you find out why it is there.
stryfox
Apr 1, 2018 03:10 PM
canadian-fire
Apr 6, 2013 09:09 PM
SRT SIX
Feb 2, 2010 01:06 PM
maxcichon
Nov 13, 2007 10:18 AM
wkirch
Jul 31, 2007 11:29 AM
