So just how bad can your paint be and still be salvageable?
Re: So just how bad can your paint be and still be salvageable?
radmanly, I would say that running a D/A at speed 6 with enough downward pressure to almost bog the machine is pretty darn extreme and I don't know of ANY company that recommends proceeding this way. The heat you developed, enough to steam a quick detailer off the surface, is pretty extreme and I would caution you against using this process in the future.
I'd love to see the microscratches you're talking about - can you describe them in more detail? Are they throughout the paint or are they very random? There is every possibility that an aggressive approach with even a medium cutting pad could be inflicting some marring to the surface, regardless of which chemical you're using. You might want to try more of a finishing polish with a less aggressive pad and less pressure/speed than you've been using.
Yeah...the steam worried me a bit. I was able to put my hand on the surface and hold it there. It was uncomfortable but not excruciating. I really don't think I did any damage but I don't plan on making a habit of doing that. I was REALLY glad I wasn't using a rotary.
The microscratches are random. A little line here; a couple of lines there. It's not pervasive. When I look at the reflection of the light bulb in the finish, it's definitely not a mirror. It looks a little "foggy" with tiny, tiny, tiny little microscratches encircling the reflection. It's when I'm squinting at those that I think maybe I've gone over the edge!
I think I am going to try the less aggressive approach. Clearly more aggressive isn't working. After my failed experiments with the Swirl & Haze, I polished the hood and front quarter panels with the Fine Machine Polish and the white polishing pad. When I was done, it didn't look that different than when I started. I pulled the car out into the sun and it looked perfect.
Does Meguiar's do detailing clinics? Any chance they'll do one in the Twin Cities of MN? I'd love to have a real pro look at this and tell me if I'm just being neurotic or if there's really something to be done here.
Originally Posted by radmanly
One more thing...my cars are Aero Blue and it seems like a lot of the cars I see that have truly mirror shines are black. Is such a shine really possible with blue paint?
Re: So just how bad can your paint be and still be salvagable?
Originally Posted by FP
Mike, obviously my paint is in pretty good condition, but I still see some spider webs. Keep in mind I'm **** and want a perfect black, no swirl marks finish. I don't trust myself with an orbital, but I probably would not trust just any pro either, because you don't alway get the best guy in the shop. Does Megs have any shop in the Chicago-Land area they would recommend?
Mike, I can't thank you enough for pointing me to the Meg's M105 product. I used it on my car yesterday, and I am as satisfied with the results as I can be. The car looks fantastic; no swirls marks at all. I finished it up with my Adams polish and wax, and the result is outstanding.
Thanks for your help. BTW, the dressing worked great too.
Your car always looks great in every picture you post, but I know how black will reveal the slightest imperfection in harsh, direct sunlight. I'm afraid we don't have a list of detailers around the country so I can't help you there, sorry.
You have a Porter Cable 7424, right? You might want to try that with some step up products like our M105 Ultra Cut Compound. We originally designed this to work with a high speed rotary but quickly altered it so that it was compatible with the 7424 and other D/A buffers. It's important to get this slightly altered version of the product because the original version gets a bit dusty when worked with a D/A. You may find that you need to alter your technique a little when using it - a bit less product, a bit more pressure, a bit longer buffing cycle - but it can do some pretty amazing things and you still don't run the risk of screwing up. I know you're a big fan of Adam's stuff, and that's cool. But this M105 is very, very unique in the way it cuts. And you won't have any issues using Adam's wax on top of it.
I have an old porter cable G100 Meguiar's polisher that I got for my vette about 10 years ago. I hope it is still a usable product to use on my car. My car looks about showroom but I know I should get some wax on it as I don't think anything was done other than the dealer prep. What is the way to proceed with my finish? Thanks Ron
o55ie18
10-05-2015 05:50 PM
