New proud owner with spots on my Graphite Coupe
Old Jul 23, 2020 | 02:17 PM
VintageBikesUSA's Avatar
Default New proud owner with spots on my Graphite Coupe
New to me 05 coupe, I have cleaned and clay bar the car, waxed it and have some touch up paint on the way but I noticed a few spots that dont seem to want to come off, sorta like the are etched into the paint on the hood mostly. Maybe water spots? Nice paint on these cars and I dont want to screw it up using a brillo pad or something. What should I do to get them off?
Old Jul 23, 2020 | 04:16 PM
Default Re: New proud owner with spots on my Graphite Coupe
Some bird poop, for instance, can do a good job of ruining the top coat, if something like Meguiars Scratch X does not get it out you are stuck with it.
Do not go at it hog wild or it could look worse in a hurry.
Old Jul 23, 2020 | 06:42 PM
Like onehundred80 stated, you'll probably need a paint polish (Meguiar's Scratch-X kinda falls into this product line), finished up with a good wax and/or sealant. If the blemish is severe enough, you might have to start with a paint compound, then a polish to remove any swirls, followed by a good wax product. I use Meguiar's product line whenever I need to use this approach. If you have access to a buffer, makes the removal of a surface blemish somewhat easier. But it's not necessary in most cases.
Forgot to mention, in some cases, I will use a product like Prep-Sol to remove the wax in the spot before starting to deal with a blemish.
Old Jul 23, 2020 | 07:04 PM
Is this damage below the clearcoat? If so polishing out the paint will require a repair of that clearcoat if I understand this process correctly, right?
Old Jul 24, 2020 | 08:26 AM
I have the full line of Meguiars and a small air driven buffer for things like this, I do feel like the more I rub it the worse it gets! Pics to come soon. Honestly, the paint on this car BLOWS away anything else and I am on my way to bringing it back.
Old Jul 27, 2020 | 01:02 PM
DTMenace's Avatar
Vintage
First try Dawn dish detergent for the areas, that will remove all of the wax. Second try a 50-50 mix of vinegar and distilled water. Thirdly, if the first two fail, try Meguiars Ultimate Compound with a DA polisher with an orange pad for those areas. If that doesn't work, the clear coat is damaged beyond repair.
Good Luck....
Dennis
DTMenace
Old Jul 29, 2020 | 10:35 AM
So it feels above the paint , I can feel it with my fingernail. It looks cloudy clear the size of a dime, like something sit on the car like leaves. The cowl was full of them. I will try some of the suggestions.
Junebug
Sep 18, 2014 02:14 PM
Michael Adrian Cronin
Apr 30, 2009 09:11 PM
Centaurv
Aug 20, 2004 08:05 AM
Centaurv
Detail Shop
Aug 19, 2004 10:19 AM
FerrariVdub
Mar 31, 2004 02:42 PM
