Just built my new ECU
Originally Posted by intenseblu
ooh i got one tid bit of info for you for when you go with the 7th injector part of the project...
make sure to use the dual table code to run the 7th injector... the standard code injects fuel even if the VE map is set to 0% across the board cause it still takes cold accel enrichment into account amongst other values... the dual table code was designed to run progressive nitrous control, so 0% means 0 pulsewidth no matter what...
Originally Posted by dynamicS
any new updates on your ecu woody??
I will be posting an update and more pics here and on my site at the weekend. The trouble is it takes almost as long to write stuff up and publish it as it does doing the actual work.
Ok, ok. I'm just dying to see you get that TBI manifold bolted up, ay, hurry up will ya...
You won't need a day job once you get all those gizmos for the XF working, I'm sure you'll make plenty of cash selling us performance aftermarket parts.
Originally Posted by woody
I am still making up the loom but have actually been concentrating on building/programming my dyno box over the last couple of days. There is also the small matter of having to go an do a proper day job too.
Woody how are you getting on ... it's been quite, does this mean you had a bad weekend?
Originally Posted by bollox
bump...
Just out of curiosity, but does anyone know who makes the Engine management computer for Mercedes Benz SLK/Crossfires??
Is it a bosch part?
Was flipping through an auto mag the other day and stumbled across an ad for NAPA auto parts, turns out they sell a ECM system too...I might have to look into this...
Is it a bosch part?
I found out that I have had both my current and savings accounts drained by some bast@rd who stole my cards from my wallet.
Is it a bosch part?
Is it a bosch part?
Originally Posted by maxxm
What a horror! I hope you have your funds restored and that the thief is caught, prosecuted, and jailed. Words are inadequate to describe what should happen to jerks like this. The worst thing, though, is that you can never recover the time you had to devote to this repulsive crime.
Woody... Gutted for you... Even if you get every penny back it is loads of stress and hassle...
Best of Luck.
Best of Luck.
I was back at the track yesterday and did some work on the ECU. Still more to do but things are moving forwards. I've updated my site with progress.
Site Update
Since the last post I have made some more progress with the ECU and actually had it running in parallel with the stock system. I still need to sort out the throttle position sensor and tidy things up a bit but so far so good.
Here's a video clip of it running:
ECU Clip
ECU Clip
Just a few pics of progress on the wiring loom from the weekend:
Temporary lash up to determine routing etc.
Who's for Spaghetti?
Nearly there...
The MAF/IAT assembly
Nearly there...
Looks like you've been working hard on this project! How are you coming along on the multi port manifold, Have you had enough time to weld one up?
The manifold is still in the planning/CAD stage. The car is my daily driver so I have to keep it more or less in one piece. I need to take the car off the road for about a week to pull the induction system apart and take all the measurements for the manifold. But before I do the multiport I am going to machine up the 7th injector plate so I at least have a completed system that may be of use to someone. I will also be removing the air pump to try and get a bit more access to the induction system and generally simplify things. There is also the small matter of finding the 600GBP for the throttle bodies! A new set of tyres have had to take priority over that.
If your looking for throttle bodies, my friend Wade Wilcox at WWE just finished production on his own T-bodies for the Cannondale fuel injected dirt bikes, they would be a perfect match for your manifold, If you would like more information I can get it along with some pictures. Price is about $700 a piece but for six throttle bodies he could come down in price to about $300 each.
I believe the flow rate on one throttle body is about 12% more efficient than the LT1 350 Chevy throttle body, sold by Arizona Speed and Marine..
Eventually he might make an entire induction system for v8 motors using the same throttle body, but right now he's just all dirt bikes.
Anyways can't wait to see what your manifold looks like!
Hey sounds great.
OK, I'll take some pix and post em up here for you to check out. Would you need to have the IAC ports or can you do with out them? One less step in the machining could drop the price some more, along with less parts to deal with...
