Oil catch tank
Did a quick SEARCH and found this.
Is this what you want?
https://www.crossfireforum.org/forum...ight=oil+catch
I would think it should be a bit easier with a Limited.
Brandon's idea works really well.
I used the same oil seperator (Husky, I believe)- I did end up having to seal the bottom petcock valve with RTV to get it to really collect the oil. I drain it every other fill-up now - nearly full each time.
Cheers,
KrzyFast
Cheers,
KrzyFast
Guest
Posts: n/a
Brandon's idea will work the same for N/A as SRT.
I installed two air/water seperators in line of the two oil hoses coming out of the valve covers. Catches a decent amount of oil.
I'm actually about to have one welded up that will look all pretty and stuff. I'll post pics when its finished.
You may use an empty plastic oil container (1litre) and just make a hole in the top near of the spout and inert a breather pipe. Seal it both inside and out with a generous bead of silicone sealant.try to refer ere www.g37forums.com/showthread.php?t=68
The PartsBin Blog.
The PartsBin Blog.
Originally Posted by Tazz
Mine is a Limited (not supercharged) and I think installation should be a little simpler ????
DeLornut
2006 Limied Coupe
81 DeLorean
Originally Posted by TVT_DESIGN
I used the same thing, but from Home Depot in the air tools aisle. Total cost was like $10.00 for 2.
Development on this separator is going forward, I was welding up Mod2.0 yesterday which should do better. Stainless steel media separates the mist from the vacuum line, without VERY LITTLE RESTRICTION. This is to reduce the crankcase pressures and free up some additional horsepower; lost due to windage.
Learning to TIG
paine2907
Oct 2, 2015 10:01 AM
