Emulsion In The Oil Cap
Old Nov 25, 2008 | 04:11 PM
harbor's Avatar
Default Re: Emulsion In The Oil Cap
Kit Fox - Are you sure that Mobil 1 synthetic was used last oil change?
Oil emulsion is common with cold weather and dino oils.
Old Nov 25, 2008 | 07:35 PM
Kit Fox's Avatar
Not sure, it has a Mobile 1 0-w40 next to the cap that the dealer said they changed it out and the oil itself looks still fairly clean. Since it was just changed right before I bought the car I figured I'd change it again right after the end of winter at the change of seasons. I don't do the full 7,000 miles a year so I plan on changing it after and before winter.
Old Nov 25, 2008 | 07:36 PM
Kit Fox's Avatar
Originally Posted by patpur
Can't help you with what it is but I can tell you I too drive short distances, only 9300 miles on my 05 and no emulsion. I've done 3 oil changes so far.
Pat
What do you mean by short distances, I literaly drive 3 miles to work it takes me less then 7 minutes to get there usually. half a mile down 25mph road, a mile down 45mph road, half a mile down traffiky 35mph road. and a mile down the highway 55mph.
Old Nov 29, 2008 | 07:43 AM
Steve - UK's Avatar
Originally Posted by Kit Fox
Taking the valve cover sounds like quite a hassle, I'm gonna look into having my oil analyzed. I'm in Chicago and it recently started getting ultra cold. When I opened the oil fill in cap the engine note did change abit after a few seconds, not sure if thats related.
Check that the engine crankcase breather is not blocked. The breather may have a small filter or one-way valve wichm might be blocked -allthough unusual, its posible that it can be gunged up. Im not sure which side of the engine the breather is, I ll check it out from the manual and come back.
good lick
steve -uk
Old Nov 29, 2008 | 08:12 AM
beanerneon's Avatar
ive seen it in aircraft engines to that during the winter when they dont get real hot
Old Nov 29, 2008 | 09:12 AM
beanerneon's Avatar
Originally Posted by georgeousrt6
no one on this forum gives a ****
who are you again? whats up with this guy lol
Old Nov 29, 2008 | 09:31 AM
Kit Fox's Avatar
^^^ Some guy who got bashed and now he is upset. Go to his profile and just put him on your ignore list, Admins have been notified and will ban him ASAP.
good lick
steve -uk
I looked in the service manual and there is nothing under "Crankcase breather" which section would I look in to find it?
Old Nov 29, 2008 | 01:02 PM
patpur's Avatar
Senior Member/Moderator
Kitfox - I'm a mile from work, a mile from shopping, very short treks. Some times if I get out of the house early I go the long way. That is about a two and a half mile trek at 45-50 mph.
Pat
Old Nov 29, 2008 | 01:13 PM
waldig's Avatar
Talking Re: Emulsion In The Oil Cap
I have many vehicles and that is condensation, if you had water in the oil it would look milky.
I have been working on a low restriction oil catch can for the intake and after some 400 miles , I had a bunch of watery goo. Remember that this can is between the valve cover vents and the intake of the supercharger. I t is intended to clear the fumes of oily vapor to keep the S/C and intake passages free from oil due to the crankcase ventilation operation. ENJOY
Hydrocarbons and blow-by do this, W DY
Old May 2, 2009 | 06:38 PM
Kit Fox's Avatar
After a few longer rides and Autocross (needle nudged over halfway a few times) it looks like its all gone.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
